Old 04-27-2015, 11:23 AM   #145
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
My ALPINE CDE-W235BT - I dig the colour changing feature :P
MedMantle is offline   Reply With Quote
Old 12-16-2015, 09:18 AM   #146
Kar98
Drives: 2011 Scion tC
To hell with the stupid Eclipse AVN2210p! Like every car stereo with a removable front plate, it's finally only working right when you stick a penny in there. Out with the old, in with the new! Pioneer AVH-X2700BS, with parking brake override by Micro Bypass (Amazon) and Axxess AX-USB-35EXT (from Sonix Electronics) to route USB and AUX input to where the factory aux-in was. Radio bezel I got from eBay Germany, leftover from when I installed the Eclipse/TomTom unit.
Old 06-12-2016, 01:10 PM   #147
Tapokata
Drives: 2009 Yaris
JVC KW-NX7000 from some years ago, installed in 2011- or about 145K miles ago, based on the odometer reading in the photos.
I fitted a rear back up camera at the same time, along with the daisy chained modules for SiriusXM, Bluetooth, and iPod (they connect through the CD changer plug on the back of the HU). I've since removed the Bluetooth module (found phone usage while driving to be too distracting, and it was real inconsistent in connecting with my Samsung S-III) and the iPod module (it has a built in USB line that controls the iPod as well, making the module a bit redundant). It also has an SD card interface, so I've found that to be more convenient for most of my audio library.
I've updated the software in the HU once, and the map files twice, but I think NavTeq has stopped supporting upgrades for this model. It used to have real-time traffic alerts on the nav side as well, by subscription through Navteq, but again the web links to re-subscribe seem to be perms-broke, and Navteq tech support denies all knowledge of every offering the service.
I used a JVC-Toyota wiring harness, running the stock speakers. Telegraph tied, soldered, and heat-shrink wrapped all of the connections on the bench. The HU has a full connector set for AV I/O, but the only connection I'm using is for the backup camera. The HU uses the OEM mounting bracket, and the DD trim kit snaps on to that- the physical installation was really pretty easy.
I like the option of changing the face screen colors, so I was able to match to the stock dash board lighting. The face plate is motorized, tillable, and can be fully detached for when I'm parked in some sportier neighborhoods.
The only other modest complaint is that the AM radio tuning sensitivity is horrible- but I think that's a byproduct of the internal antenna design on the car as much as anything.
Tapokata is offline   Reply With Quote
Old 01-22-2017, 05:12 PM   #148
David C
Drives: White '07 3dr LB
I changed mine to a Kenwood Excelon 599, added a SSL Lo-Pro 8 powered sub (remote next to the voltmeter), digital voltmeter and a custom 4 switch setup.
Left to right :
1/2 for selecting which battery bank voltage to display (secondary battery behind the driver seat)
Momentary push button for the deep tone big rig horn
On/off rocker for switched A/C (to disable A/C when using the 3 defogging ventilation controls)
On/off rocker switch for head unit power (independent from accessory key position)
Tuned the rgb color of the display to a smooth faded blue (best color for my eyes all around, particularly night time driving), all my music uncompressed on the USB flash drive, using Bluetooth for hands free calls, don't really use all the other features like Sirius, Pandora, iHeartradio, etc. My cluster is white in color with red gauge needles, so it's smooth and easy on the eye (my definition of luxury). Used Metra harness and DIN mounting bracket, free with the purchase of the head unit from Crutchfield.com
Doesn't have a dimmer function like the stock unit did, but you can tweak the color and brightness to a good balance for both day and night.
Voltmeter and switch lights are crisp as the heading display, despite how my camera decided to show it.
Envoyé de mon iPhone en utilisant Tapatalk
David C is offline   Reply With Quote
Old 04-28-2017, 09:29 AM   #149
Vitz_RS
Drives: 2006 Toyota Vitz RS Hatch Back
Pioneer AVH-5800BHS
Sent from my SM-G900H using Tapatalk
Vitz_RS is offline   Reply With Quote
Old 04-28-2017, 11:18 AM   #150
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Nice
On Instagram
On Wheelwell
Old 04-28-2017, 02:39 PM   #151
Vitz_RS
Originally Posted by ern-diz View Post
Nice
Thanks!
Old 05-05-2017, 01:05 AM   #152
miiser
miiser's Avatar
Drives: yaris 2009
Guys you think I should change the HU first or add an amp?
miiser is offline   Reply With Quote
Old 05-05-2017, 01:12 AM   #153
miiser
miiser's Avatar
Drives: yaris 2009
Old 05-15-2017, 06:21 AM   #154
David C
Didn't you already changed your speakers since last thread ? If so, change the HU first since it will give you better sound adjustment and more power, as well as auxiliary output for amps if you still feel like one afterward.
Old 06-02-2017, 08:09 PM   #155
David C
Front dash kit from a RS trim, glossy black match the new deck a lot better than the stock silver grey.
Old 06-02-2017, 08:19 PM   #156
ern-diz
ern-diz's Avatar
Very nice
On Instagram
On Wheelwell
Old 09-03-2017, 09:07 PM   #157
govtec
Drives: 2007 Toyota Yaris Hatchback
I went the Toyota Scion OEM route...
govtec is offline   Reply With Quote
Old 09-04-2017, 03:32 PM   #158
ern-diz
ern-diz's Avatar
Looks Good. How was the improvement in sound quality?
On Instagram
On Wheelwell
Old 04-23-2018, 02:34 PM   #159
twiceover
Drives: 2007 Nautical Blue Yaris Sedan
Wife got a new (to her) 4Runner with the stipulation that I get a new receiver, speakers, window tinting, on my 2007 Toyota Yaris with integrated radio. I installed cheap Alpine 6.5" in the doors and matching Alpine 6x9" in the rear deck and a Pioneer AVH-2300NEX as the receiver. I would have liked a sub, but I'm old.
See attached image.
twiceover is offline   Reply With Quote
Old 04-23-2018, 10:34 PM   #160
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
And now for something completely different. JDM OEM!
Plug and play Toyota touchscreen HU with VOICE NAVIGATION! (Navigation obviously doesn't function outside of Japan ) Needed an AUX in, which this HU's TV input works well enough for, and of course it can play my MiniDisc collection.
Old 04-24-2018, 11:17 AM   #161
ern-diz
ern-diz's Avatar
Ha that's
On Instagram
On Wheelwell
Old 04-24-2018, 02:54 PM   #162
Wait, thought you sold the LB?
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
