Old 04-29-2009, 02:08 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
bump for update...
Old 04-29-2009, 02:55 PM   #2
jkuchta
Drives: 2007 Yaris hatch (red)
MGragano, What is the code for the CEL? Have you adjusted the idle set screw yet?
jkuchta is offline   Reply With Quote
Old 04-29-2009, 05:15 PM   #3
MGargano
Drives: 2009 Yaris Hatchback
P0505- Idle Malfunction. No, I haven't adjusted the idle screw.
MGargano is offline   Reply With Quote
Old 04-29-2009, 04:43 PM   #4
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
9 PAGES and i still see a CEL.......
Old 04-29-2009, 06:41 PM   #5
jkuchta
That's why you get a CEL. You MUST adjust the idle to get rid of that CEL, as it's a result of the ECU having to over-adjust to hit a target idle RPM. Re-read thread #78, and you will more than likely get rid of the CEL for good.
Old 04-29-2009, 09:32 PM   #6
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
no you dont. i didnt touch my idle screw, its still covered in the hard crap. all i did was the chip swap, nothing else.
Old 05-02-2009, 04:11 PM   #7
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Cool thanks for the diy.
I got my 1zz tb from crxgames. I removed the rivets, swapped the chips, screwed them on, and added some rvt gasket maker. Plugged in the new 1zz tb with the 1nz chip and started her up. This was after I had disconnected the battery for an hour. So it started to oscilate from 2-3k like many others have mentioned. I waited for exactly 10 minutes and it ended up idling at around the same rpms as the stock tb. Drove around a bit and no cel. I didnt mess with the idle screw cause the idle was just fine. I had to run some errands and every time I started up my car no problems or cel. I have yet to start my car during a cold start up so I'll chime back in here with results. The ecu hasnt learned the changes completely yet, my auto keeps shifting too early still. I can tell theres gonna be a ton of power over 3k. I'm not sure thought, but i think i'm feeling a lot of increase in low end...@_@
Getting some headers worked on right now, should compliment the TB very well.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-02-2009, 04:22 PM   #8
jkuchta
Mike, Mgargano's specific CEL is more than likely caused by the idle screw not being adjusted.
Old 05-02-2009, 04:28 PM   #9
right -- read the whole sentence above, it's to get rid of a CEL. If you didn't get a CEL, you don't have to adjust it.
Old 05-03-2009, 09:16 AM   #10
marcus
toyota
marcus's Avatar
bumpin..
Old 05-05-2009, 11:02 PM   #11
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
HELP!!!!!!!! PLEASE!!!!!!!! I am in the middle of installing this TB with the afe intake the issue I am having is the coupler for the intake is hitting the screws and wont go on all the way. I have tried with all my strength to push it on further with no luck. Also I am unable to wedge the hose clamp in between the coupler and the screws. Any Ideas? I was thinking about shaving out some of the inside of the coupler, but how would I go about doing it? here's a pic so you can see what I amj talking about.
Old 05-05-2009, 11:06 PM   #12
MGargano
I have my 1ZZ installed with an AFE intake also. I bolted the TB to the intake manifold first, then slid the coupler onto the TB as far as it would go, right up to the studs. I couldn't fit a hose clamp on there either, but I've driven it about 1,000 miles with no problems. The coupler is wedged in between the intake and TB pretty tightly, so I don't think you'll have any problems with it moving/leaking. I know others are using the same TB & intake with no hose clamp, so I think you'll be fine
Old 05-05-2009, 11:09 PM   #13
Yaris T-Sport.
Yaris T-Sport.'s Avatar
Drives: .
thats why I use a bigger hose clamp
Yaris T-Sport. is offline   Reply With Quote
Old 05-05-2009, 11:15 PM   #14
MGargano
It wasn't the width/diameter that was a problem, it was the length of the TB's neck that stuck out past the studs. It was barely wider than the hose clamp itself, so it kept slipping & popping off
Old 05-05-2009, 11:18 PM   #15
Yaris T-Sport.
Drives: .
maybe use a few zip ties?
Old 05-05-2009, 11:04 PM   #16
mikenacarato
SIPNDEW
Drives: 15 STI
and you cannot get the clamp to clamp tight just before the studs?
Old 05-05-2009, 11:08 PM   #17
MGargano
I tried to use a hose clamp when I did the install the first time. It stayed on for bit, but once the engine got hot, the clamp popped right off. The neck of the TB isn't long enough to clear the studs & fit a hose clamp.
Old 05-05-2009, 11:28 PM   #18
PHXDEMON
PHXDEMON's Avatar
I guess ill just run in without the clamp and cross my fingers
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
