Old 07-21-2009, 03:50 PM   #1
tforkner
Drives: 08 liftback 5 speed
Here's how I did my clutch switch. I used a SPDT submini roller lever switch, Radio Shack # 275-0017. I superglued it in place on the metal bracket.
tforkner is offline   Reply With Quote
Old 07-22-2009, 11:00 AM   #2
TylerJ
Drives: Blazing Blue 2007 3dr HB 5MT
Thanks for those of you who responded to my question. I am thinking about doing this mod this weekend. I will update on how it turns out.
TylerJ is offline   Reply With Quote
Old 07-22-2009, 11:40 AM   #3
bronsin
bronsin's Avatar
Does anyone know the Toyota Part Number for the dash panel next to the ignition switch? (the one I put the switches in for the CC) Im thinking it would be handy to have in case the car needs warranty work!
Old 07-22-2009, 05:00 PM   #4
55446-52060-B0
Old 07-22-2009, 07:48 PM   #5
bronsin
bronsin's Avatar
Thanks much appreciated!
Old 07-23-2009, 02:19 PM   #6
bronsin
bronsin's Avatar
55446-52060-BO is $22 BTW.
Old 07-26-2009, 02:15 PM   #7
TylerJ
So I had everything soft wired in last night and it worked perfectly. When I ran all the wires today and tried it after buttoning things up nothing happened. I think my jumper for the clutch cruise switch in the fuse box got moved when I snapped the lid back on. This is the coolest thing to have cruise for so cheap.
Old 07-31-2009, 06:23 PM   #8
WDmac
Drives: Black Yaris sedan
2009 yaris sedan cruise control
Hello, I just bought a 2009 yaris sedan and wanted to put the $10 cruise on it. When I got into the bottom of the steering wheel colum, there is only 1 black wire coming out of the connector shown in CTSCOTT's diagram. Any ideas? Thanks.
WDmac is offline   Reply With Quote
Old 07-31-2009, 06:42 PM   #9
I believe that someone else found that as well. That means that the 09 Sedans are like the 07-08 liftbacks, which means that you will need to run the wire yourself from the ECM to the switches. Take a look at this thread, working your way from the end back for more details:
http://www.yarisworld.com/forums/sho...=16188&page=29
Old 07-31-2009, 07:03 PM   #10
WDmac
Thanks
Thanks a lot I appreciate the time you took to post all this info. Looks like you have helped a bunch of people save some money. I'll check out that thread and let you know how it goes. Thanks again
Old 06-13-2014, 01:27 PM   #11
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
09 sedan no wires???
I have an 09 sedan! The wires are there under my steering wheel!
I will post pics tomorrow on the install......
trunkout is offline   Reply With Quote
Old 07-31-2009, 06:46 PM   #12
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I havent seen anything yet I dont think, how do you remove the friggin dash, lol, I dont wanna break any clips, so can anyone post a pic with the screw and clip locations highlighted?
Old 08-22-2009, 01:42 PM   #13
G6-R
Drives: CHR 1.8 Hybrid + Yaris gen3
I bought a brandnew Yaris 1800 T-Sport 3 doors ( delivery date in about 2 months from now )
I have a original cruisecontrole handel from a Corolla Verso 1800 can i use it for the Yaris Cruisecontrole ?
G6-R is offline   Reply With Quote
Old 08-22-2009, 01:50 PM   #14
No. For whatever reason, the European Yaris doesn't have cruise programmed into the ECM.
Old 10-22-2009, 01:21 PM   #15
Antipilor
Drives: 2008 Yaris 5-speed
So I think I might have screwed up somewhere, I just notice in the last day or so after I installed this mod (stills not working but I havn't had time to track down the problem). I noticed that the airbag off light on the passenger side will light up only for a bit randomly while driving. The airbag on light works fine when someone is riding with me. Any ideas on what I did wrong?
Antipilor is offline   Reply With Quote
Old 10-22-2009, 01:32 PM   #16
The two are probably unrelated. The airbag light occasionally flickering may be due to the empty seat weight calibration being off.
For the cruise issue, start with your connection at the ECM. Make sure you are in the correct pin there. If you just want to verify that the cruise and airbag issues are unrelated, disconnect the cruise wire to the ECM.
Posting pictures of your connection to the ECM and you resistor setup/wiring to it will help as well.
Old 08-29-2009, 07:56 PM   #17
julienrl
Drives: 2007 yaris
Hello, I wanted to do this but could not find the parts (even with the part numbers) for the covers\panels on the dash (so I can swap it for the normal one if I take the car in for servicing or something or want to sell the car as a trade in in the future), so I made the mirror cover one myself! It happens to be a hobby of mine to make plastic objects \ casting and molding, so if anyone needs a mirror cover, the master mold is made, and since that was the expensive part, i can make them for pretty cheap if anyone wants one for 10$ shipping anywhere included :). Takes about 24 to have one made and ready so it could be sent pretty quickly.
julienrl is offline   Reply With Quote
Old 09-02-2009, 10:08 PM   #18
taka
Drives: 2008 Sedan
Thank Scott for this DIY.
System is installed and working. Couple things I found on my 2008 Sedan: The wire is already installed between ECM pin 40 to connector AD4 under the dash. Instead of running a new wire from ECM or disassemble the dash to get to the wire from the top of AD4, I push a long pin up from the bottom of connector AD4 (pin 9) for wire connection to the switches.
My two spring loaded off toggle switches are mounted onto a existing blanking hole located beside the park brake handle. Toggle switches operation are: System enable/disable on each toggle and Set/Coast (when held). Sorry I would have posted photo of the installation if and when I find out how to.
taka is offline   Reply With Quote
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
