Old 07-23-2009, 03:40 PM   #1
texkid
The one with cheese on it
Drives: '10 Corolla S
Originally Posted by Lafiro View Post
Now thats a silly question about cruising, or stop and go. Where do I live? lol Its all stop and go, even the highways 80% of the time.
Sorry, never been to NYC. In Houston, San Antonio, and Dallas, yeah there is primarily stop-and-go traffic but once you get a bit of the ways out, you can fly at 70mph without a problem. LoL!
Let us know what are the results after the foam approach.
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 07-24-2009, 12:38 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
well, since the heater tube didn't bend as well as I had hoped for I had to use more electrical tape, and make more pieces of tube than I had wanted. So, it doesn't look as nice as I was hoping, but it still looks decent. I also ended up deciding to go without any foam.
The electrical tape is good to 220 degrees F, and the tubing i'd think would be good to at least 300 F. The tubing is fairly thick, so I don't think foam is necessary.
Yesterday I was able to finish the first lil curved pieced located near the radiator before the fiance got home. Will try and finish the rest tonight.
I won't have numbers on mine, since I only use AC about every two months when I do a 1000 mile trip. If nothing else, wrapping it in rubber tubing should help protect the pipes from corrosion or any damage from happening to them.
Old 07-24-2009, 12:45 PM   #3
supmet
Drives: 2007 4 Door Yaris
That's an interesting point. If you wrap it in foil tape, it keeps water out. But if its just foam and zip ties like most people, I wonder if there is a chance of it actually increasing corrosion, giving the water somewhere to sit touching the pipe, rather than just hitting the pipe and evaporating or just sliding off.
Old 07-24-2009, 03:11 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
well... moisture will only foam where there is air present, so, if the foam is perfectly on the pipe with no gaps or pockets for air, there will be no moisture. That's not practical however.
Another point tho.... moisture will only form where there is a significant change in temperature.... gotta drop the temp below the dewpoint with the given humidity....so, even if there are pockets of air under the foam, if the foam is insulating well from the outside, it still shouldn't be much of an issue.
I'm not a huge fan of using the foam simply for fire/heat issues.... and covering it up with that aluminum tape.... ehhh... looks ugly I think. I'm sure foam and tape however will be a better insulator than what i'm doing. I however don't really have much of a complaint with my ac to begin with... but figure this will help some, and on long trips, this might help me keep the AC off a bit more... thus increasing mpg's. Total weight added will be less than a pound too.
Old 08-03-2009, 05:17 AM   #5
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
ricepower is offline   Reply With Quote
Old 08-03-2009, 02:16 PM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
finished over the weekend.... don't have net at home anymore.... neighbors moved out... will take pics and try to upload them at work sometime this week. Using electrical tape was a pita because of the hot line that runs very close to the cold line getting in the way. I can see why the original poster used zip ties. I'm also sure that foam would work better than heater core tubing like I used... tho, not nearly as safe (I don't have to worry about high temps or hot liquids).
Old 08-03-2009, 03:05 PM   #7
LOL - you were "borrowing" internet access?
Old 08-03-2009, 04:31 PM   #8
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I prefer the term looting... maybe even stealing. Don't worry, I was all ninja about it... they didn't know.
Old 05-31-2010, 09:12 PM   #9
IsLNdbOi
IsLNdbOi's Avatar
Originally Posted by texkid View Post
First off, I really should THANK Echo-hrs for the idea. If he never mentioned in the first place, I probably would've never know to do this to my car. I went to my mechanic for some help. After taking a look at my car, he definitely agreed that the Low Pressure line needed to be insulated.
I purchased a meat thermometer to get a reading on how its running BEFORE I started doing the insulation. Below is the reading with the A/C set to (4) on Recirculating, with all vents open; driving from work to home (roughly 20 minutes) ABOUT 50-DEGREES
Here is temp, with the car in the drive-way and windows half open. Its 120-freaking-degrees!
AND FINALLY, here is the temp AFTER the insulation driving for 15 minutes. A DROP OF ALMOST 10-DEGREES!
So, without further delay, on with the DIY.
Disclaimer: I am not responsible for what happens to your car. Do this at your own risk.
Tools:
- A pack of foam pipe covers (.75 cents at Wallmart)
- A pack of 6 inch wire ties or whatever you call them
As far as the zip ties are concerned, DO NOT tie them too tight like I did. Just enough tension to keep them in place is all that is needed.
- A meat thermometer
- A couple bottles of water
- SHADE!
Instructions:
Lets start with what the hell we are insulating. It is the low pressure line going from the firewall to the rubber hose before it hits the condensor. Its marked with a pink line at the firewall and has a pressure valved labeled "L". When run the A/C, this line should be the only one that is COLD to the touch. The smaller line that sits below it should be open to air as it is taking hot air out of the cabin and back to the condenser.
next: get your foam pipe insulation and check to see if it fits. If its too loose, you can trim off a bit. But just a BIT!
-Start at the firewall end since it is most difficult and cramped part of the job. At this point, it is recommended that the engine is cool to touch. I singed a couple of arm hair before I realized that. LOL!
-Run it as much as you can, once you hit that big, "drum" looking thing, cut and start tying it down. As far as that "drum" looking thing, you're just going have to get creative and find a way to cover it. But it does make a difference when you do.
-For the other side, grab a piece and run it from the front side and thread it under the engine mount. Tie that down very well and make sure nothing can hit the belt or the alternator.
-For the rest of the low pressure line, just keep tying it down until you hit the rubber hose. I shouldn't have to tell you this, but cut holes where needed such as the low pressure valve and that do-hicky you see below.
-AND YOU'RE DONE! Cut off the excess straps so they won't get tangled into anything.
Ok so it's been almost a year since this thread was made.
Anyone found / notice and negatives to doing this? Has it really made a difference in a/c efficiency?
Old 06-02-2010, 11:37 AM   #10
Henry G.
Drives: 2008 Yaris HB
Yep it definitely works. I used the aluminum tape over the foam and zip ties and its all still holding together nicely. Check the clearance at the back of the motor between the exhaust manifold and AC line (when the cars cool), its about an inch and half. Does that make sense? No!!
Henry G. is offline   Reply With Quote
Old 06-05-2010, 10:31 AM   #11
metalshark
MetalShark
Drives: 2008 Yaris LB
Pros and conns
On the Pro side it will help fuel economy because the compressor is a variable compression design as most are these days. On the con side if you were over charged and running AC on a cool day you would let liquid refrigerant into your compressor producing hydrostatic lock. When I do mine I will use aluminum tape over the insulation to reflect heat away from the insulation. That makes it way harder to melt the cheap insulation with under hood heat. The other hyper-miler tip here in Phoenix is to tint the windows. Both this insulation and window tint will cut the mileage drain AC caused here in Lucifer's waiting room. Window tint alone reduces the fan setting you have to use to wear a suit when the outside air temp on the express way says 1198 degrees F. I get 39 MPG here at 65 MPG on cruise lock. I've been watching for a trick to break 40 under the same harsh conditions. I average 42 city and highway so hyper-mile tricks between lights does work. Our winter mileage is even better than that. From my sig you can also see the other mods that allow better than EPA mileage results.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 06-03-2010, 02:40 PM   #12
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Did Mine Too !! (on an XD)
I read this thread and decided it was a good "investment" Mod so here you can see what the result was....
I used The Wiring Loom instead of aluminum for cosmetic reasons and wanted the engine bay to look a little neater... The loom has not degraded or shown any signs of overheating, so mybe it will last....(hopefully)
There is enough of it in the engine bay already so it should do fine.
The DIY results were as good as I expected.
You can see the final result at this link:http://www.scikotics.com/forums/showthread.php?t=192547
Aloha From Hawaii !
bobolinko is offline   Reply With Quote
Old 06-07-2010, 12:33 AM   #13
90tsi
90tsi's Avatar
Drives: 09 yaris
funny i just did this several hours ago. lol took like 30mins. i thought it worked well. worth the whole $2 in supplies i used.
90tsi is offline   Reply With Quote
Old 06-07-2010, 12:37 AM   #14
IsLNdbOi
IsLNdbOi's Avatar
Where can I get the supplies to do this?
Old 06-07-2010, 03:13 AM   #15
kazama82
Drives: VIOS
To share my DIY..mine is yaris sedan
kazama82 is offline   Reply With Quote
Old 06-07-2010, 03:02 PM   #16
Echostatic
Drives: 2007 Toyota Yairs
I'll be trying this out this afternoon and probably taking video of the process, if anyone would find that useful. Here's hoping the shade is enough to stave off the 100 degree heat...
Echostatic is offline   Reply With Quote
Old 06-07-2010, 03:19 PM   #17
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
Video DIY's are always welcome!
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Old 06-07-2010, 03:35 PM   #18
severous01
anyone try headerwrap and speed tape? the aluminum ducttape? thinner, probably better insulator with the shiney tape...and you know it wont catch fire lol.
i think i'll get some header-wrap and see for myself.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
