View Poll Results: Would you buy one?
No 5 5.10%
Yes (for $75) 46 46.94%
Yes (but it would have to be less than $75) 7 7.14%
Yes (but I still want it to also display the time) 40 40.82%
Voters: 98. You may not vote on this poll
Old 01-08-2010, 01:26 PM   #145
Originally Posted by jdms View Post
any estimated time when these will be available?
sorry to keep beating a dead horse
I expect to be shipping by the end of January. I have the production build parts on order.
Old 01-08-2010, 03:48 PM   #146
POORSHA
POORSHA's Avatar
Drives: 2008 LB
would you like to take payment so we can start lining up?
POORSHA is offline   Reply With Quote
Old 01-08-2010, 03:50 PM   #147
Not yet. I don't like to take people's money until I am ready to ship.
Old 01-08-2010, 08:41 PM   #148
goku87
goku87's Avatar
Drives: Black HB
I'm way excited for these even though my yaris has gone to yaris heaven lol.
Old 01-08-2010, 09:58 PM   #149
yea im going to pick one of these up, you said it was going to be a code reader as well?
Correct (reader and resetter).
I am calibrating the temperature sensor input on my car (and on Crashy for comparison) right now.
Old 01-09-2010, 01:49 AM   #150
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
so cool!
mr9865 is offline   Reply With Quote
Old 01-09-2010, 01:26 PM   #151
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Wow,this is probably the coolest idea I have seen done in years for any car.....you sir are a Saint......finally a tach for the car....yes.
Old 01-09-2010, 03:39 PM   #152
yarstar
Drives: 2008 Absolute Red HB
CTScott is tha MAN!!! Can't wait. Thanks again for doing this.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 01-09-2010, 04:09 PM   #153
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
we all owe Scott a big THANKS!
Lewis is offline   Reply With Quote
Old 01-09-2010, 07:07 PM   #154
Lucas13
Drives: 07 Yaris LB
This looks awesome I really want one! Great Job CTScott!!!
Lucas13 is offline   Reply With Quote
Old 01-09-2010, 08:29 PM   #155
RedRide
RedRide's Avatar
I'm impressed!
I want it!
Old 01-10-2010, 12:57 AM   #156
Here's another teaser - Mounted in my 09 with the orange LCD:
Old 01-10-2010, 01:05 AM   #157
advocate
Drives: car
How does the unit install to the car Scott? Does it read from the OBD2 port?
Old 01-10-2010, 01:18 AM   #158
Once the full production units are complete, I'll post the install pictures, but basically: You unplug the clock's connector, pop the clock module out, and pop the YarGauge in, in its place. I realized tonight that only 3 tap splices will be necessary, as I can have the clock's power connector plug right into the YarGauge. The three taps are for CAN communication (two taps on the right cluster connector) and one to the AC amplifier for the outside temperature (which is easily accessible by the gas pedal). It uses the same switch lever as the clock as well.
It communicates with the ECM via the CAN bus, but it grabs it at the cluster, so you can still have a scangauge or other device use the OBD port.
Old 01-10-2010, 02:08 AM   #159
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
just too cool for words
Check out my Build thread:
Old 01-10-2010, 02:24 AM   #160
advocate
Drives: car
And what about clusters with the clock on the other side? Will compatibility be similar?
Old 01-10-2010, 11:25 AM   #161
RedRide
RedRide's Avatar
I like that it will be able to maintain the stock, orange color.
I do have one question ...
I noticed that in the last pics, the cluster brightnees is turned up to what seems to be to max but the modual seems a bit dimmer than the other displays.
If you were to turn the brightness down a bit like at night, will the new modual still be as visible as the rest of the cluster?
Will the new modual indeed be able to be dimmed along with the cluster?
Old 01-10-2010, 12:22 PM   #162
Right now I am not using the dimmer feed, so the display would be the same brightness with headlights on or off. Now that it is in the car, that's one thing I'll experiment with to determine if dimming is needed (I have a feeling it won't, as the backlit LCD is not as bright as the speedometer).
in dash clock as tach? Cosmonaut In Car Entertainment + Electronics (audio / video / alarm) 10 07-12-2010 11:27 AM
digital tach, 52mm, preferably blue leds severous01 Cosmetic Modifications (Exterior/Interior) 5 05-15-2009 10:58 AM
Digital Tach nqd Performance Modifications 4 05-17-2007 12:04 PM
