Old 03-01-2011, 08:34 AM   #145
ibanezjeepguy
Drives: 2010 Meteorite Liftback
http://www.trdsparks.com/displaypart...&parts_id=2306
pretty cheap stalk & wire combo. for the screws just get some from hardware store I believe they're M5 x 0.8 , same as xbox 360 heatsink
ibanezjeepguy is offline   Reply With Quote
Old 03-01-2011, 09:07 AM   #146
Also, I have a couple of the stalks with the wire and the screws for $40 shipped, which is less than half of that price.
Old 03-01-2011, 09:09 AM   #147
ibanezjeepguy
how long have you had those? I could've used an awesome deal like that last year!
Old 03-01-2011, 10:11 AM   #148
About two months ago a friend of mine got me a few at dealer cost.
Old 03-01-2011, 01:17 PM   #149
DSprague
Drives: 2010 Yaris sedan black
I'm in, how do I pay you?
Dan
DSprague is offline   Reply With Quote
Old 03-01-2011, 02:05 PM   #150
Dan
PM sent.
Old 03-09-2011, 11:30 AM   #151
Originally Posted by cicici00 View Post
I have been really busy and did not have any chance to install my cruise control since I bought my OEM stalk from ebay (like months ago). I finally find a weekend to do this thing. I just want to make sure I get the set-up right before I break into my car.
I have a 2008 LB Yaris.
1. I first cut off the red+black wire clip at the end of the stalk
2. I see the "Spiral Connector Repair Terminals" in the parts requirement. I wonder if I really need it, if I treat the stalk = diy switch/button. Can I hook it up like in Fig. 1?
3. I think I will get "ECM repair terminal" for Pin 40. I know CTScott sells them. Since I finally find a free weekend to do it, I need that part sooner. So, I wonder if I can buy that from Toyota Dealership and get it on the same day? Or can I just get one from the junk yard? Or if Advanced Auto / Auto zone / radioshack sell them?? I am just afraid if I don't do it this weekend, it will be months after I can do it again.
4. I thought about just insert the wire into Pin 40. But, I am scared it will not be secured. How far do I need to insert the wire into the A21 ECM? Does the ECM terminal has some clip to hold all the wires in place? Anyone here did it without the "repair pin"??
Thanks again for all the help!!
1/2. You don't really want to clip the connector. If you are planning on mounting the stalk in the steering wheel, then it needs to go through the spiral cable.
3. If you want to use the pins, I can ship them today via priority mail for $5 more (bringing the total to $15 for the three pins), so you would have them in hand before the weekend. I believe that the dealer price on them is $12 each, so you would still be saving quite a bit, and I don't think that dealers typically stock them.
4. People have done it this way, but it does not always make good connection and is not sealed, so it will allow moisture to enter the connector.
Old 03-14-2011, 06:42 AM   #152
Originally Posted by wasserburgandy View Post
hi guys, i am from China, I own an Yaris made by Toyota China. Does anyone here know if the China version Yaris can install the cruise control or not? People here say the ECU doesn't support. tks
I don't have any of the wiring diagrams or manuals for the Chinese Yaris, but as far as I know, only the US/Canada 1.5L Yaris ECMs have it built in.
Old 03-14-2011, 08:57 AM   #153
BTW, do you have any file that records installing the CC by using original Toyota parts stalk& wire in detail with pics?? tks.
Look at the first page of this thread for links that show the installation of the OEM cruise stalk. From your pictures, you don't have the 1NZ-FE engine, which as far as I know, is the only one which has the ECM preprogrammed for cruise control.
Old 03-18-2011, 08:29 PM   #154
CB900F2
Drives: 08 Sedan
Scott.. Would you happen to have a photo the the top half of AD4 connector as I got the connector off the white mount, but since it is a bit tight, I am having a hard time trying to find the latch to unhook the two halfs?..
Thanks Scott!
Here is more detail on AD4:
Connector location under dash (the gray connector next to the blue and yellow connectors at the top left section of this picture):
Attachment 39851
More detail on the connector's location (this is the male side {which is on the bottom when in place in the car} of the junction connector that is part of the dash harness):
Attachment 39848
This is how the male pin gets inserted into the connector:
Attachment 39849
Detail of the male pin:
Attachment 39850
CB900F2 is offline   Reply With Quote
Old 03-18-2011, 10:00 PM   #155
Thanks Scott!
Old 03-19-2011, 05:28 AM   #156
CB900F2
Drives: 08 Sedan
Thanks Scott!
Old 03-19-2011, 12:49 PM   #157
Originally Posted by cdu View Post
I'm so confused...lol! I've gone through so many threads and am not sure where to start! I first came upon this video: http://www.youtube.com/watch?v=bWPXFYeLJj0
He makes it looks so easy but then I realized, after spending time on two threads here, that he doesn't touch on any of the engine work that also needs to be done.
I have an 07 Sedan/Automatic and live in Canada.
I know tons of people have asked this question and hate to do this to you guys but...what parts do I need for MY car?
Any help would be much appreciated!
That's why I just put this together. This is the detailed soup to nuts instructions for all aspects of installing OEM cruise control on any Yaris from 2006-2011:
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 03-21-2011, 08:55 PM   #158
CB900F2
Drives: 08 Sedan
Installed the CC on my CND version 2008 Sedan and all went well, I want to give big thanks to every one and especially Scott for all of his great help!
I installed the OEM CC stalk and ran the CC signal line from D3 to AD4, getting to AD4 was not too bad, just trying to work in the small area under the dash was the only challenge. Grounded the GND line from D3 was no issue.
I recommend the up grade to anyone needing CC
Thanks again to Scott for all his great help and supply of connectors.
Old 03-28-2011, 08:57 PM   #159
Aetre
Drives: 2009 3dr Liftback
Hi, all. Newbie with a 2009 3dr liftback automatic and the dumb question of the day:
What parts of this cruise control installation, if any, would void the warranty?
Aetre is offline   Reply With Quote
Old 03-28-2011, 09:41 PM   #160
ibanezjeepguy
none...
Old 03-29-2011, 12:03 PM   #161
Aetre
Sweet, thanks.
Old 03-29-2011, 07:47 PM   #162
ibanezjeepguy
as long as you're adding toyota OE parts everything should be fine.... its when you start adding in your own home-brew stuff that things become grey
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
