Old 06-04-2015, 11:20 PM   #1
nookandcrannycar
Originally Posted by mark293 View Post
177,000 here. Still on original brake pads. Recently changed the manual tranny fluid to Redline. Soooo smooth. Replaced the serpentine belt and side window trim this morning. Best car I've ever had, and I've had a bunch. Bought it on a whim to pull behind our motorhome. The motorhome has been long gone but I will NEVER part with my egg.
I feel the same way about my egg. However, given the point of the car's 'life' when my accident occurred, it doesn't make sense to make the repairs. I'm going to teach a friend to drive a manual on it (if we can find a big enough empty parking lot ), and then donate it....in one fashion or another. If I ever come across the proverbial little old lady who has an '11 5-speed Meteorite Metallic or White 3-door with the split rear seat...who 'only drove it to church on Sunday' (so to speak)...and has decided to part with it, I'd probably buy it in a heartbeat.
Old 05-30-2015, 11:10 PM   #2
2009Toyotoad
Drives: 2009 Yaris 3dr
My 09' HB has 108k and still getting 40+ MPG.
2009Toyotoad is offline   Reply With Quote
Old 06-12-2015, 08:08 PM   #3
darkat65
Drives: 2008 Yaris Sedan
149,000+ miles (240,000+ km) on an '08 manual that my 17 year old learned to drive standard on and still going strong.
darkat65 is offline   Reply With Quote
Old 06-21-2015, 02:37 PM   #4
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
now at 357000km about 222000 miles on the body and the second engine has 264520 km or 164365 miles due to hydro locking the first engine! Still running strong, this car has been through alot, and still getting over 600km/375 miles per tank. Replaced broken lowering spring, center exhaust and have to change the clutch.
Adriaan is offline   Reply With Quote
Old 06-22-2015, 12:14 PM   #5
coheed
Drives: 08 BB LB
180xxx here, bought it with 5k on the clock in '09. Only things that have had to be replaced are the shifter cables, right rear wheel bearing, and the serpentine belt a few times (aside from the 2 accidents).
Old 06-24-2015, 03:00 AM   #6
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
Why did you replace the shifter cables?
Sent from my SAMSUNG-SM-N910A using Tapatalk
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 06-24-2015, 12:51 PM   #7
nookandcrannycar
You are our 'holy grail' when it comes to mileage and longevity for original owners (and even for original engines)!
Currently, how high is 'the summit'...how many miles on your Yaris ?
Old 06-25-2015, 11:37 AM   #8
coheed
Drives: 08 BB LB
It was a very odd situation. I went out to drive my car one morning and I could only shift 3-4. The side to side cable had seized up . Mind you this was the first year I had owned the car with roughly 30k on the odo. Not sure what was wrong, or what caused it, but they set me back $287.
Old 06-25-2015, 06:29 AM   #9
trini_per4mance
Thank you! I currently have roughly a measly 543,000 miles on my Yaris. This may sound crazy to the average person out there, but I'm going to turbocharge it in the near future. My Valve Seals have now started to leak when I run thru the RPM's. So, I'm burning oil and have to top it up about every 1000 miles.
You never answered my question as to why you changed your shifter cables... Lol. I'm really interested to know why and if it fixed your problem. Bcuz currently I have a rattling noise from my linkage on my gearbox. But when I pull or push the shifter towards any gear while in neutral (which I'm basically put tension on the shifter cables by doing that), the noise goes away. So, I was thinking that maybe I should change out my cables too. Let me know what your issue was with your cables.
Thanks!
Old 06-25-2015, 08:35 AM   #10
nookandcrannycar
Thanks!
Thanks for the reply to my post ! Sorry, I'm not the member who changed his shifter cables . You are quite an inspiration, so members like to hear about your current odometer mileage (...and putting on many fewer miles than you used to doesn't change that curiosity) and what you are currently doing with your Yaris . This has come up on threads since you last posted . Some of us know we can check your maintenance/repairs and mods on your '500,000 miles on my Yaris' thread. Post #1 on that thread shows the mileage interval that you did repairs/major maintenance, and mods, but doesn't hint to a current odometer level (last update to that page - January 2014). I don't think it's crazy that you're going to turbocharge your Yaris at 543,000 + miles . Given your maintenance intervals, etc., I'd imagine there isn't a 500,000 mile plus Toyota anywhere in the States that is in better condition than yours. Definitely update post #1 on your '500,000 miles on my Yaris' thread after you install the turbo setup (and create a thread foe thgat as well if you are so inclined ). I hope the member who changed his shifter cables answers your question.
Old 04-24-2016, 01:30 AM   #11
bairjo
Well I'm in the club...103,000 miles on my 2010. No issues here. Guess I should change the oil now...lol.
Old 05-02-2016, 11:00 AM   #12
billfires
Drives: 2010 3dr LB
Just turned 100,000 on my 2010 HB. Oil & filter changes, air filter and tires have been the only maintenance items. Bill C
billfires is offline   Reply With Quote
Old 05-02-2016, 11:56 AM   #13
texascolt45
Drives: 2015 yaris
I got 15,000 since august of last year.
texascolt45 is offline   Reply With Quote
Old 05-02-2016, 12:53 PM   #14
bairjo
15,000....Congratulations. .....You are almost there.
Old 05-06-2016, 05:13 PM   #15
jose1969
Drives: yaris d4d
Hi there!
I'm just getting 100000 miles on my '08 yaris d4d in few days....no problems until now
Edit: yesterday the battery just said goodbye and the check engine light is in the dashboard.
jose1969 is offline   Reply With Quote
Old 05-08-2016, 05:11 PM   #16
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I hit 102k on the chassis recently on my 07 sedan.
Sent from m-o-b-i-l-e
Old 06-14-2016, 12:15 PM   #17
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
I'm at 253k right now... I'm starting to wonder if I should proactively swap the alternator, fuel pump, or water pump? I have a 75 mile each way commute into town and don't want to get stranded. Car drives perfectly though!
Cosmetically my front end has been chipped all to hell by all the construction around Atlanta. I'm planning on having the front end totally repainted and using Xpel on the front. Nothing else has really taken a beating like the front... the damned main road through the city was practically a gravel for a few weeks!?!?!
firebird1999us is offline   Reply With Quote
Old 06-14-2016, 09:12 PM   #18
CB900F2
Drives: 08 Sedan
170,000Km on my 2008 Sedan... And runs and looks like a champ!..
CB900F2 is offline   Reply With Quote
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
30,000 mile service: Dealership or non-dealership? EstherK DIY / Maintenance / Service 1 11-12-2008 12:40 PM
11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) Jerkratt NY / NJ/ CT / PA 14 10-26-2008 05:51 PM
Japanese Mix Club Los Invitamos!!! TunTun_yariS[PR] Caribbean 0 12-12-2006 12:03 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
