Old 10-19-2024, 06:41 PM   #145
Cris_co1221
Drives: 2007 Yaris 3dr
Originally Posted by Cris_co1221 View Post
I am having the same issue, but a 2007 3dr manual. I have all oem parts but cc not working, and same voltage issue when depressing the on/off switch.
My issue was pin #2 on d3 wasn’t fully inserted (ground wire), got that hooked up and am fine now.
Cris_co1221 is offline   Reply With Quote
Old 06-01-2025, 10:19 PM   #146
scott10301
Drives: 2007 3dr Hatchback
Just did the install today and no luck. I have a 2007 with no indicator light and want to troubleshoot to see if I'm at least the switch to the ECM is working.
How do I troubleshoot this? I saw that some are mentioning that they're testing voltage while depressing the on/off switch. Are you removing the pin from the D3 connector and then using a multimeter to test? I'm not sure how else that would be done. I did pull the pin and checked and am getting 13.3 volts whether I press the on/off button or not.
scott10301 is offline   Reply With Quote
Old 08-11-2025, 05:20 PM   #147
scott10301
Update - I found the issue. The splice connector under the hood was not set up properly. Set it up correctly and all is working well.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
