Old 06-11-2012, 09:27 AM   #145
Originally Posted by djgab101 View Post
guys so i found a motor with 29 000 kms on it! I want to rebuild the bottom end so forged pistons and rods!
How difficult is this DIY, i have pretty good knowledge on cars! I have the toyota 1nzfe full specs on engine remvoal and overhaul with pictures and instructions on how to do everything but can any one offer advice on ?
This recent thread is probably the best one on that subject:
http://www.yarisworld.com/forums/sho...t=39407&page=4
Old 06-11-2012, 10:09 AM   #146
pimp and his friend did it themselves. I had my bottom end built by someone else.
Old 06-11-2012, 10:31 AM   #147
djgab101
djgab101's Avatar
Drives: toyota yaris
i have been watching that thread has some really good pictures and information!
might see once all the parts how difficult it might be!
djgab101 is offline   Reply With Quote
Old 06-13-2012, 10:35 AM   #148
djgab101
djgab101's Avatar
Finally got my car from the tow company Sunday I shall start stripping down my car! Find out wat actually happened to my engine!
Would everyone agree that my engine has been damaged from a bad tune? If it's only on 8psi with engine damaged tune seems to be the problem!
Old 06-13-2012, 11:50 AM   #149
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I know this is kinda far fetched.. but If it you had the money, when ever a check engine light comes on, the ecu will take snap shots of (correct me if im wrong) 10 seconds before the CEL came on and after. So you can see what ALL the sensors was reading when your engine blew up. Ex, oil pressure drop, fuel mixtures, knocks/pings.
only reason i say this is pure curiousity.. At lexus, we could see what happend and what RPM, engine temp, etc. the CEL took place and try to duplicate it.
Like I said. It's a long shot and would prob have to pay for a tow truck and pay a diag fee.. They can use thier laptop TechStream tool and print out a copy for you
-Derrick-
Old 06-13-2012, 05:48 PM   #150
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
May need to go to a Toyota dealer to get scanned with the oem scanner to get that freeze frame info.
Old 06-13-2012, 06:04 PM   #151
pimp my yaris
C'est la vie
Building the engine yourself is certainly possible, but I wouldn't call it easy. I was lucky to have a friend with some experience with a few engine builds under his belt to help out with checking piston ring end gaps and assembling crank main caps just right. I also worked as a dealer mechanic for about 12 years. Although I installed many engines in that time and also removed many cylinder heads, I never rebuilt a lower end or short block. I am pretty sure I could pull it off this build by myself now but if I didnt have the helpful tips I got I may have just dropped the short block off at a "known good" engine builder.
Good luck whatever path U choose
Old 06-13-2012, 06:38 PM   #152
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
speaking of a good know engine builder, is Ptuning the only company that offers a bottom end build for the 1NZ-FE?
Old 06-13-2012, 08:34 PM   #153
^ Nope. We can get that done for you. My car is a great example of a reliable, well-built result.
Ptuning has a great rep as well, and might be geographically more desirable.
Old 06-13-2012, 09:09 PM   #154
Golddeenoh
Golddeenoh's Avatar
yea but if I send it to Cali to get done then I get to bug you more :D ;) don't worry wont be soon but I'm starting to plan it more and more, now to give the wife some money for her down payment on a new 5.0 then I can reinvest money into another Yaris+build
Old 06-14-2012, 09:52 AM   #155
djgab101
djgab101's Avatar
I know wat you talking about and yes that is a great idea but how much it would be is another thing cause toyota by me where not even interested in doing a basic service on my car cause it was modified i had to sign papers so they are liable!
thanks for ur advice! greatly apprepicated looking around and thinking all options avaliable
Old 06-14-2012, 11:37 AM   #156
ilikerice
ilikerice's Avatar
yea, completly understand. I still have small connections with toyota, until everyone I used to work with finally quit or retire, so I can get access to techstream tool. Again, if no connections its basicly if you have money to throw away.
Anywho.. good luck on your build.
-Derrick-
Old 06-24-2012, 11:09 AM   #157
djgab101
djgab101's Avatar
Okay started pulling it apart haven't got the engine out but found a huge crack under the 4 cylinder smashed so bad hit my turbo piping made dents and small hole! Also have a major crack near the starter motor! Hopefully have the engine out and disassembled soon!! I will post photos tomorrow of the progress
Still umsure about my rebuild tho
Old 06-24-2012, 08:43 PM   #158
pimp my yaris
C'est la vie
Everybody loves pictures!
Old 06-24-2012, 09:03 PM   #159
+infinity
Old 06-26-2012, 02:19 PM   #160
thefalls
Drives: Axio GT
As above,pictures will be a boost for us.
thefalls is offline   Reply With Quote
Old 06-30-2012, 06:55 AM   #161
djgab101
djgab101's Avatar
Who can spot the Problem!? ahah
well i have finally got time for my car just need a engine hoist to take it out then ordered nesscairy parts to put it all back together again! my 4th cylinder was the problem seems rod broke made holes everywhere front bottom and back has holes! not sure about the top! i am sure u can see it in the pictures!
Old 06-30-2012, 03:12 PM   #162
whoa. OUCH
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Boosted Yaris Quarter Mile Times 1.5 Forced Induction Forum 0 01-03-2010 05:49 PM
Yari Boosted, Enge lite... N3misiS Forced Induction Forum 14 11-20-2009 07:22 AM
Going Boosted FryGuy Forced Induction Forum 53 03-01-2009 10:01 PM
PE Boosted Yaris Video jinxor Forced Induction Forum 16 02-06-2009 02:33 AM
