Old 08-10-2014, 10:14 AM   #145
dobrik
Drives: Yaris 2013 1.33 CVT
Hi CTScott,
Do you know if your CC kit would work on Rav 4 2011 CVT (european model)?
Thank you
dobrik is offline   Reply With Quote
Old 08-10-2014, 12:14 PM   #146
Originally Posted by dobrik View Post
Hi CTScott,
Thank you
I believe it will, but I will do some research to confirm.
Old 08-11-2014, 03:14 PM   #147
dobrik
thanks!
Old 09-15-2014, 06:16 PM   #148
stykerdk
Yaris Hybrid Limited 2015
Here is the how to for ap900c in Danish but it is simple.
http://www.asmarketing.dk/f/f1/AP900...iesel-2009.pdf
You Will also need the wire tharness no 190-5002220
http://www.autobutik.sk/product-21529-190-5002220/
Old 02-11-2015, 05:15 AM   #149
karloslatynos
karloslatynos's Avatar
Drives: 2012 Yaris TR 1.33 VVT-i Man
Originally Posted by stuart_f View Post
Also ordered from CTScott and got the parts in UK very quickly and no customs issues (despite USPS tracking saying the package is still in USA!)
I notice my steering wheel assembly is slightly different from Richard_RSP's (but thank you for the pictures that helped a lot in knowing what I was aiming for.
I have the steering wheel audio and also the bluetooth telephone control on my UK Spec 2012, 1.33 Yaris TR Auto (not sure which bit of that means I have the different clips though!)
Also, pin 1 & 2 of the 10-pin connector are already occupied so I put the cruise in the spare 4-pin socket next to it.
Edit- It works!
Hello everyone,
CTScott, I've received your kit (thank you).
I've tried to install that today but got stuck when tried to remove the airbag. The steering wheel of my Yaris is exactly the same like one on the pictures above but I couldn't get access to the clips. The steering wheel back cover has only one hole (in the middle). Any idea how do I unclip the remaining two?
thanks
Had a look athe post 55 (thanks Stuart_f) & hopefully I will be able to manage to do this way
karloslatynos is offline   Reply With Quote
Old 02-11-2015, 12:56 PM   #150
Kirill
Drives: Yaris 2009 1.3 sol 100HP
Hello C Scott,
I have the 2009 yaris Sol 100HP MMT transmission I will appreciate your help. could you please check if it possible to install the cruise control on my car?
Kirill is offline   Reply With Quote
Old 02-14-2015, 01:17 PM   #151
w1p30ut
Drives: Toyota Yaris Icon Hybrid 2014
Big thanks to C Scott.
Fitted mine this week and it works a treat. Reasonable easy to install except for one stubborn spring clip>
Thanks again.
w1p30ut is offline   Reply With Quote
Old 02-14-2015, 02:27 PM   #152
karloslatynos
Finally got my cruise control kit installed and tested on my Yaris III. Works perfect and I find it very usefull.
The installation process is very simple exept removing the airbag. It was absolutely nightmare! The access to the side clips is very limited. As somebody said in the post 55 the side clips required to be lifted. I couldn't do that with the clip located near to stalk control. I even removed two screws holding the audio panel on the steering wheel to make more room to access that bloody clip. Finally I've managed to completely pull out the clip from it nest and the airbag popped out. What a relief that was.... I was able to start breathing again. The rest of the installation process (including final push the airbag to the steering wheel) took less than 5 min.
I strongly recommend to all Yaris users to get the cruise control from CTScott. The price is reasonable and as I mentioned before its worth every penny.
Old 02-25-2015, 06:03 AM   #153
karloslatynos
I have tested the cruise control on a long trip (Birmingham UK - Brussells BEL) & I am so impressed with it. Apart of driving comfort it also has reduced the fuel comsumption big time.
Someone said to me that using cruise control will increase breake pads usage. How does actually work? Does cruise control use breaks to keep constant speed while driving downhill?
Old 02-25-2015, 06:45 AM   #154
GustavAlshauge
Drives: Toyota Yaris T-Sport
Heyy, im new here, i have a yaris 1,8 vvt-i Ts. Do any of you know if i can get the original toyota cruise control to fit in my car??
GustavAlshauge is offline   Reply With Quote
Old 02-25-2015, 07:01 AM   #155
GustavAlshauge
ps, my Ts is from 2007.
Old 02-25-2015, 07:58 AM   #156
Cruise control does not have the ability to actively brake the car. It can only do so with engine braking.
Old 02-25-2015, 07:59 AM   #157
Unfortunately there is not an OEM solution for your Yaris.
Old 05-18-2015, 07:25 AM   #158
haunter1982
Drives: Yaris 1.33; Edition 2014;
Hi there.
I have installed the switch, the Cruise Control works with no problems, BUT the lights in the dash are not active.
Could it be that there a no bulbs installed? I think this should be LED or not?
Someone have an idea?
One hint for dismounting the Airbag.
The first spring is simple, just press a screwdriver into the hole on the bottom. (as described here in the thread)
The second spring comes of through the side-panel, which you have to remove to see the spring and later install the switch (also as described here in the thread)
The third spring seems complicated but as the holes are elongated you only have to slide the hole Airbag-Unit a little to the otherside and the unit comes off.
haunter1982 is offline   Reply With Quote
Old 05-19-2015, 05:53 AM   #159
Some of the European instrument clusters are not equipped with the indicator.
Old 05-19-2015, 07:23 AM   #160
haunter1982
Damn. I can see the sign but it doesnt light up. Are there bulbs or LED's in the Instruments?
Old 05-20-2015, 02:20 PM   #161
LEDs
Old 05-24-2015, 07:35 PM   #162
scmoky
Drives: Yaris 2012
Haunter
I'm from Slovenia, and have same problem. CC from scot works flawless, but no light indication. I tried to check if there are some leds, but gaguge needle is hard to remove or i don't now a right way to remove to check if there are missing two leds.
If there are not any leds, maybe if solder up some leds an try?
scmoky is offline   Reply With Quote
cruise control. 2012
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
