Old 01-10-2016, 02:51 PM   #145
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Not sure yet, but don't believe so. The behavior of this pump however is very similar to the last one. Started off fine however as time went on it became louder and louder. AEM determined the first pump was actually missing internal fittings that frankly could have caused a catastrophic event. I was very lucky. The only reason why I used another one was because AEM covered all costs.
Sent from m-o-b-i-l-e
Old 01-10-2016, 02:54 PM   #146
LTHatch
Drives: 2013 Yaris Hatchback L
Ah i see, do you have any safety nets in place if there is a fuel pump issue during a land speed run?
LTHatch is offline   Reply With Quote
Old 01-10-2016, 02:55 PM   #147
1nz revolution
Drives: 1nzfe
WELDON FUEL PUMP. Best race pumps on the market. AEM doesn't even make theirs. All those designs are all based off Walboro.
1nz revolution is offline   Reply With Quote
Old 01-10-2016, 03:17 PM   #148
fnkngrv
fnkngrv's Avatar
Not really when it comes to that.
Old 01-10-2016, 03:20 PM   #149
fnkngrv
fnkngrv's Avatar
Your new threads and posts smell a like like you are Aras. Am I correct?
Old 01-10-2016, 03:26 PM   #150
1nz revolution
Drives: 1nzfe
Surge tank set up. No chance of starvation.
Old 01-10-2016, 06:05 PM   #151
fnkngrv
fnkngrv's Avatar
If TBR would like to sponsor the car by assisting with safety equipment, etc then they know where to reach me. Other than that posting up about very expensive components that will not be purchased or put into the build is moot. There is a reason the build is taking the path that it has which is that it is still driven on a regular basis when weather permits. The back seat gets used as well as the trunk so at this stage a fuel cell with inline components is not realistic. This has not changed in the 5 years the car has been run heavily modified and right now no plans to change that.
Old 01-11-2016, 08:44 AM   #152
Focus_Sh1ft
Focus_Sh1ft's Avatar
I have an Aeromotive A100 in the tC, and it's LOUD. I wouldn't worry too much about the noise unless you're beginning to have fuel starvation issues.
Old 01-11-2016, 02:26 PM   #153
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
5 years later.. still haven't seen that xB run...
-Derrick-
Old 01-13-2016, 12:42 PM   #154
fnkngrv
fnkngrv's Avatar
It doesn't really bother me too much unless I am standing outside the vehicle while it idles or at a stop light, etc. I guess that I just need to get used to it for a while. I should have converted to an inline pump and then could have wrapped it in sound deadening material like some folks have, but my updates went over budget as it is.
Old 01-18-2016, 07:30 PM   #155
fnkngrv
fnkngrv's Avatar
The car will be receiving the new Tanabe Coilovers in the a.m. in preparation for being loaded on the trailer in the afternoon to make the 250 Mile trip to the Dyno. Wednesday we will see how things are really looking.
Old 01-20-2016, 10:00 AM   #156
fnkngrv
fnkngrv's Avatar
First time ever she has been on the scales. Have to reduce the weight by whatever my subwoofer box weighs. More than I was figuring, but with the added weight of the turbo, associated components, etc I suppose I can't complain.
Old 01-20-2016, 10:04 AM   #157
was that with you in the car and a full tank of gas?
Old 01-20-2016, 10:08 AM   #158
fnkngrv
fnkngrv's Avatar
1/2 tank of gas no occupants.
Old 01-20-2016, 10:18 AM   #159
If it ever comes down to it, gasoline weighs about 1.6 pounds per liter.
Old 01-20-2016, 01:55 PM   #160
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
...or 6 lbs per gallon, if you wanna keep the same system of measurement.
Here in Canada, it's all just a big mix, and people just use whatever is more convenient or feels more natural to them. lol
Old 01-20-2016, 02:26 PM   #161
There's two different measurements of gallons so it's way more confusing to me.
Sent from my iPod Touch
Old 01-26-2016, 09:57 PM   #162
fnkngrv
fnkngrv's Avatar
Some post dyno day action items:
Had to order a couple fuel filters. $20 thru Summit.
Also had my 3rd oil sending unit die during the pulls so ordered another one plus braided line to remotely mount it to the crash bar. They don't seem to stand up to the vibration very well. That came to around $80.
Lastly the BOV spring is apparently too stiff because it isn't opening completely fast enough when letting out of the throttle after full boost. The surge keeps popping one of my pipes of the IC due to the tight angle of the pipe. So ordered the spring kit from TurboSmart for $20.
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
