Old 01-08-2016, 08:52 AM   #145
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
The only significant difference is they increased compression from 10:1 to 10.5:1(Edit: and Valvematic). Otherwise they are almost identical
Old 01-08-2016, 08:57 AM   #146
Originally Posted by ArmstrongRacing View Post
The only significant difference is they increased compression from 10:1 to 10.5:1. Otherwise they are almost identical
And the MAJOR fact that it uses a different head and valve system to control RPM not a throttle body.
Old 01-08-2016, 08:58 AM   #147
Originally Posted by 3cyltrbo View Post
sorry I got lost in the details, I thought the 2zr-fae was different than the 2zr-fe?
The blocks should be nearly identical, it's the head and valve train that differ.
Old 01-08-2016, 10:23 AM   #148
ArmstrongRacing
Data doesn't lie
.... the question was about transmission compatibility haha....but thanks for the info!
Old 01-08-2016, 06:58 PM   #149
ArmstrongRacing
Data doesn't lie
Started disassembly today
Old 01-08-2016, 07:04 PM   #150
Is the car stuck in a lot right now, or is this where you work...??
Old 01-08-2016, 08:49 PM   #151
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It's an automatic? So sad. =P
On a semi-related note, the engine harness ECU pinout for the xD is wildly different from the Yaris. Like, 99% incompatible. I haven't documented the smaller connector yet, but it will likely be different, too.
The actual component connectors, however, seem to be identical, if named/numbered differently. E.g. the engine bay wire harness ECU connector is C20 in the Yaris, but C19 in the xD.
Edit: just compared the connections on the 60-pin ECU side--about 90% incompatible. Both connectors are incompatible in possibly catastrophic ways for the ECU. Moral of the story: DON'T SWAP ECUs WITHOUT SWAPPING WIRE HARNESSES!
Old 01-08-2016, 10:19 PM   #152
ArmstrongRacing
Data doesn't lie
Im a Tech at the dealership...
Yes it is a auto, because its my only car and Im not trying to teach my pregnant wife manual.....i have a 5spd on standby for when we have a second car.
We swap everything over from the Xd, EVERYTHING lol.
Regarding the diy...do I need to include pulling the 1nz? Or just the assembly and install of the 2zr?
Old 01-09-2016, 07:01 AM   #153
Frank the Tank
Drives: 2007 Toyota Yaris
Just a quick question regarding swaps since that's the subject here
Why doesn't anyone swap the 2zz into the yaris?
Edit: the more information the better
Frank the Tank is offline   Reply With Quote
Old 01-09-2016, 08:07 AM   #154
fredovvti
Drives: Yaris 07 HB
I think only assembly and install of the 2zr. There are manuals and videos in the web to how dessembly de 1nz.
fredovvti is offline   Reply With Quote
Old 01-09-2016, 08:08 AM   #155
It's not a "Bolt In" able swap. You'd need to do some major fabrication to get it to fit.
Old 01-09-2016, 10:09 AM   #156
Rigaud
Drives: 2009 Yaris
That and it's NOT a plug and play for the ECU. Been done with success by some in Europe and Asia. Crazy motor but a big project for those who dare.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 01-09-2016, 01:32 PM   #157
ArmstrongRacing
Data doesn't lie
AND the fact that the 2zz is crazy expensive....I actually considered this swap before the 2zr untill I added up all the related costs. $2000+!
Old 01-09-2016, 11:34 PM   #158
3cyltrbo
Huh?............maybe I was drunk with optimism, but I thought it was as simple (basically speaking) as
unplug and remove 1nz
plug and install 2zr
=enjoy 30whp+ gain
whats all this talk about the wiring being 99% incompatible ?????
3cyltrbo is offline   Reply With Quote
Old 01-10-2016, 12:02 AM   #159
ArmstrongRacing
Data doesn't lie
@Crankyoldman was referring to using the 1nz harness on the 2zr. I never once suggested that, Ive said from the beginning to use everything from the 2zr. The 2zr engine harness plugs into the 2zr ecm on one end along with the chassis harness, and it plugs into the fuse box at the other end. Sinmple.
Old 01-10-2016, 01:20 PM   #160
Dark Paw
Drives: 2006 Toyota Vitz RS. 5spd.
Dark Paw is offline   Reply With Quote
Old 01-11-2016, 08:49 AM   #161
Focus_Sh1ft
Focus_Sh1ft's Avatar
Focus on the swap and assembly, don't worry about a guide for pulling the motor.
Is the 2ZR ECU mounted in the engine bay in the XD? Regardless, is there a reasonable way to mount it in the engine bay in the Yaris?
Old 01-11-2016, 10:56 AM   #162
ArmstrongRacing
Data doesn't lie
2zr ecm mounts in the exact same way as the 1nz ecm.
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
