Old 08-13-2009, 05:43 AM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Just finished installing my tach, but I haven't connected the illumination wire. I don't know which way to go, the brown wire from the dimmer or the #9 fuse?
I'd like to have dimming for this one, but I guess I can live without it, I prefer connecting it to the fuse even if that doesn't give me dimming. Can anyone confirm?
Old 08-13-2009, 10:58 AM   #2
RedRide
RedRide's Avatar
I connected my tach's illumination wires to the #2 fuse (Panel1).
I also added a "dimmer" that you might be intetresed in.
http://www.yarisworld.com/forums/sho...light=dim+tach
Old 08-16-2009, 02:22 AM   #3
fmicle
fmicle's Avatar
Finally got this project done. Cutting the hole in the glove compartment with only a 1/8" drill and sand paper was a bitch... Quite happy with the result though
I also connected the illumination wire to the illumination fuse in the fuse panel. Don't remember the number by heart, but it's in the owner's manual. So I get the tach light on whenever all other instruments are lit.
Old 07-05-2010, 07:00 PM   #4
darkMINI
Drives: 08 hatch
So what if your tach signal wire on the OBDII plug is orange instead of greenish-blue? I have an '08 3-door M/T.
darkMINI is offline   Reply With Quote
Old 07-05-2010, 08:54 PM   #5
RedRide
RedRide's Avatar
Later models do no have the greenish-blue wire for the tach.
My '09 for example has a brownish wire for the tach.
Just use the wire that is in the correct position regardless of what the color might be.
Old 07-05-2010, 09:05 PM   #6
darkMINI
Drives: 08 hatch
WILCO, thanx
Old 07-12-2010, 10:45 PM   #7
darkMINI
Drives: 08 hatch
Ok, next question, got the tach mounted and hooked up. Its an 8,000 rpm tach and it for reads perfectly up to 3,500rpm, but it for some reason won't budge any further. Ant ideas? Thanks
Old 07-13-2010, 01:13 AM   #8
fmicle
fmicle's Avatar
Defect? Can you see any obstruction that would prevent the needle from moving?
5% Tint Rear | Micro Image LED Ignition Light Kit
Old 07-13-2010, 02:27 PM   #9
darkMINI
Drives: 08 hatch
I guess it could be a defect. I have everything hooked up except the Illumination wire, and I don't believe that matters.
Its a 4,6,8 cylinder model and the switch is set on 4.
Old 07-15-2010, 01:13 AM   #10
fmicle
fmicle's Avatar
Yeah, if it doesn't want to move past 3500 rpm, there must be something wrong inside...
Old 07-16-2010, 01:37 AM   #11
darkMINI
Drives: 08 hatch
Yep, went back to the auto parts store and borrowed a brand new one to compare it right in the parking lot. It turns out I had a bad tach, so they swapped me for the good one on the spot. Now I'm in business!
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
Old 07-16-2010, 02:01 PM   #12
RedRide
RedRide's Avatar
Glad you got it workin'.
Where did you mount your tach? Is is a panel mount or a pedestal mount?
Old 07-16-2010, 01:45 AM   #13
fmicle
fmicle's Avatar
Haha, sounds familiar, I had the same problem with my tach, got a new one, worked fine, so I returned the bad one.
Old 09-22-2010, 02:38 PM   #14
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
Fmicle, did you mount your tach in the glovebox? I cant see the pics.
CueBall is offline   Reply With Quote
Old 09-23-2010, 01:13 AM   #15
fmicle
fmicle's Avatar
OK, try to click on the links directly...
http://public.blu.livefilestore.com/...720.jpg?psid=1
http://public.blu.livefilestore.com/...723.jpg?psid=1
http://public.blu.livefilestore.com/...724.jpg?psid=1
Old 09-22-2010, 02:42 PM   #16
sleey0
Drives: 2008 Yaris LB
Wish some company would come out with a nice A pillar guage pod already lol.
I am not a fan of drilling thru the driver's side compartment like that.
I suppose even using guage pedastals and drilling them into the A pillar would work (garm had a pic and he did this with his tc IIRC).
sleey0 is offline   Reply With Quote
Old 09-22-2010, 03:10 PM   #17
maxxman420
prop215.
maxxman420's Avatar
Drives: Toyota Yaris LB
i really need to do this. i have the same tach but in white. mine is just sitting where that johnson and johnson thing is sitting in the side cluster. haha
maxxman420 is offline   Reply With Quote
Old 10-15-2010, 12:14 PM   #18
metalshark
MetalShark
Tach dreamer update: I've finished the 33 LED analog display installed in the display trim similar to my earlier BS2 tach. Those of you from the LA basin may have seen the only operational prototype of the gen 1 tach. I've finished the firmware (with the help of Prallax.com forum members) on a breadboard for a digital readout. It's running in my Yaris today. I'm changing the 4x7 segment display from red to green. I had a setback learning to solder surface mount chips for the analog display.
I'll have to do a version 1.1 layout before it's kit ready. I love the headrest video camera mount I found here. When success is apparent watch for the video coming soon to a forum near you.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Liftback Spoiler Installation Toddhata Cosmetic Modifications (Exterior/Interior) 25 08-09-2009 01:26 AM
US Yaris: Adding a tach? Thirty-Nine General Yaris / Vitz Discussion 159 04-05-2007 08:23 AM
