Old 10-27-2009, 02:38 PM   #145
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
so excited that this worked. So everyone do this since the new ones won't have drl's, the lucky peoples.
Colin Chapman disciple
Old 11-13-2009, 09:19 AM   #146
amtoro
amtoro's Avatar
Drives: 2009 3LB Metheorite
Do any of you know if the relay assembly can be installed in a yaris that did not come with DRL?
If it is possible, let me know if you want to sell your module, I'd like to have DRL's
amtoro is offline   Reply With Quote
Old 11-13-2009, 01:39 PM   #147
The wiring changes are fairly significant to add DRLs to a non-DRL equipped car. Did your 09 come without DRLs, or did you buy a used one where someone disabled the DRLs?
Old 11-17-2009, 09:18 PM   #148
Kaya B.
Thank you for your detailed how to.
I'll try in my 2010 tomorrow.
Kaya B. is offline   Reply With Quote
Old 12-22-2009, 11:18 AM   #149
Kaya B.
hey, we couldn't find the relay...
also, the authorized service told it can be turned off from computer. but they couldn't... :(
Old 12-22-2009, 01:43 PM   #150
It definitely can't be turned off by the computer, as it is a completely stand alone device.
Is your car right hand or left hand drive?
Old 12-22-2009, 01:46 PM   #151
upgradedyaris
Drives: Yaris & Supra
It took me less than 5 mins, seriously, to take this out. Three screws, pop off panel and unplug the relay/box. (I left my little box in the OEM location, just unplugged it.)
upgradedyaris is offline   Reply With Quote
Old 12-27-2009, 06:30 PM   #152
Kaya B.
my car is left side driven.
thanks.
Old 12-27-2009, 11:02 PM   #153
thanks.
In that case, the running light relay module should be located in the same place as the picture below. The running light module is the black box to the right of the steering column with the brown and white label.
Old 12-30-2009, 10:25 PM   #154
upgradedyaris
I think they cause more issues. I have seen a Yaris twice now, with the day times on and no tail lights at night. I stopped one and said, your lights are not on. lol She said, yes they are, I said NO, they are the daytime lights, you have to turn the headlight switch.
Old 01-01-2010, 08:57 AM   #155
Kaya B.
Yes,
I found the relay. It's different from yours :(
My car is Left side driven 2010 Yaris LS(Canadian Model)
The relay is under the (i don't know how to say in English.) place for putting personal things. at the right side (passenger side) near the air condition air filter. it is at the right side under the passenger airbag cancelattion button.
when i unplug the wires the headlights never on. if i turn the lights on or off...
your part number is 82810-52040 but mine is 82810-52060 :(
so i have to plug it back to power headlights :(
(sorry for my bad English.)
Old 01-01-2010, 09:09 AM   #156
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Glovebox or glove compartment.
(I doubt a lot of them get used mainly for carrying gloves, though.)
Old 01-01-2010, 09:17 AM   #157
Black Yaris
der Zeck
Black Yaris's Avatar
Yes,
I think there is something different to disable the daytime running lights in the Canadian models. It is federal law that the lights must be on at all times, and I am sure that is why there is a different box to control them.
Old 01-01-2010, 10:02 AM   #158
Yes,
I found the 82810-52060 DRL module listed in the parts catalog from Japan. I have the wiring diagram for it, as well. It is wired into the car a little bit differently from the one on our US cars.
Looking at the wiring diagram, I believe that you can disable the daytime running lights, but still have the headlights function correctly by cutting the blue wire, which is next to the violet wire. After cutting the wire, you would need to tape or wire cap the two ends.
If you try it, cut it about 5 cm from the blue connector, to leave enough to reconnect it, if it doesn't work (Although, I am fairly confident that it will work).
Old 01-02-2010, 11:00 AM   #159
Kaya B.
Attachment 30985
thank you. i just cut the blue wire today and nothing changed :(
so i put the blue wire back :(
Old 01-02-2010, 12:00 PM   #160
When you say nothing changed, do you mean that the running lights still remained on?
Old 01-02-2010, 04:01 PM   #161
Kaya B.
yes, daytime running lights are still on :(
Old 01-02-2010, 05:33 PM   #162
OK. Do you have a volt meter? That pin is definitely the one that controls turning the running lights on or off. For the US version of that module, letting that pin float (cutting the wire) works. For your version, if we can measure the voltage from the blue wire to the chassis ground with the engine running and with the headlights off and then with them on, we can figure out if that pin needs to be tied high or low on your module.
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
