Old 04-19-2014, 01:06 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Question EEPROM programming tips
Hello all
I am working on my combination meter swap project (changing my JDM meter over to a UKDM meter)
I am currently looking into the EEPROM of the meter to be able to correct my odometer reading. I was hoping someone could give me some tips. I am an electrical and electronics engineer so I do understand some of the lingo (though I never specialized in the microprocessor and programming part)
My EEPROM reader has test leads that can directly attach to the meters board (so no need to desolder the chip). I am able to read the data however each time I read it the values change, then sometimes I get read errors. Could the onboard oscillator be causing problems ? Is it better that I remove the chip anyways so that other things on the board dont interfere?
JudgeM is offline   Reply With Quote
Old 04-19-2014, 06:46 AM   #2
On the US meters I can read and program the EEPROMs without removing them, but for SRS ECUs I have to remove the EEPROM to clear the crash data, as something else on the board does interfere. I also find that the clamp on socket is very temperamental. I typically have to hold it with one hand while poking keys with the other. The 3M test socket never works correctly for me, but the Pomona works pretty well.
Tags
eeprom, odometer
Gas Savings Tips That Don't Actually Work! MadMax Fuel Economy Forum 21 03-09-2011 09:25 AM
Exhaust tips eht13 Cosmetic Modifications (Exterior/Interior) 15 04-04-2010 12:06 AM
exhaust tips what do you think? 06silveryaris Performance Modifications 32 08-01-2009 01:22 AM
