Old 04-28-2023, 07:49 PM   #1
Door Hinge
If it's even possible, does anyone know how to replace upper driver side door hinge without removing the fender?
Old 04-29-2023, 02:10 AM   #2
sh0rtlife
in theory if you pulled the ENTIRE door you "might" be able to but you would have to remove the entire fender splash pan to get up there..by way of pulling the door side bolts first you should have it out of teh way to get at the hinge...but i cant confirm this
Old 04-29-2023, 10:30 AM   #3
I have found replacement pin and bushing kit. The mystery to me, without removing the hinge, would be getting existing pin and bushings out. I suspect the answer is grinding off head of pin somehow.
Old 04-29-2023, 01:30 PM   #4
sh0rtlife
i gotta admit ive never looked that close at our hinges but yes if we have the smashed type you must grind
Old 04-30-2023, 09:19 PM   #5
remcafee
whats wrong with your hinges?
Old 04-30-2023, 09:48 PM   #6
Sloppy door, bushings worn out.
Old 05-01-2023, 12:20 AM   #7
sh0rtlife
having delt with countless sloppy hinges over the decades 9-10 its a better fix to replace them...that is unless they have a FULL THICK brass bushing kit where ou have to drill the hinge to a specific ID and damn neer press in the new bushings..anything else has always been a bandaid best used on a car your selling
Old 05-01-2023, 06:29 PM   #8
remcafee
you tried squirting some lithium grease on them already?
Old 05-01-2023, 08:34 PM   #9
What does lithium grease have to do with fixing a sloppy hinge?
Tags
hinge, remove, replace
