Old 10-21-2010, 01:11 AM   #1
FSANE
FSANE's Avatar
Drives: 07 4d yaris and 02 Trans Am
Question any networking Gurus here?
Here is the Situation.
I have a apartment in Miami, FL that I go to once or twice a year.
I have a TV there and I bring my laptop with me. When I get there I always need some kind of internet service. I live on the 9th floor I get a lot of Wifi networks from my neighbors but they are all Password protected. Now I am not here to ask how to Hack into my neighbors Wifi. I do however have a neighbor that lives on the 7th floor on the same side of the building, but just a few doors down. I know him personally. His Wifi is PW protected as well, but he gave me the PW and a full access to his network.
Now my problem is that I can't catch his signal from my floor. I need to extend his signal probably to his balcony, so this way I can catch it from my balcony. He has a cisco router. How do I go by doing that?
The reason for this is that I can watch my TV through Slingbox and of course use internet when needed.
thanks.
02 T/A AUTO Metalic Silver. 07 Yaris M5.
Best ET is 11.13 @ 120 MPH with 1.47 60FT
11.13 sec vid
BurnOut Vid
FSANE is offline   Reply With Quote
Old 10-21-2010, 01:46 AM   #2
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
You need either an external antenna hooked up to his router (I've installed a few hotels the same way) or a range extender.
This one looks nice...no wires.
http://www.tigerdirect.com/applicati...895&CatId=4026
There are other solutions, but they all come down to extending the range of your friend's signal.
chrisj is offline   Reply With Quote
Old 10-21-2010, 02:02 AM   #3
BailOut
Steals terrorist's lunch
BailOut's Avatar
I've deployed several Linksys WRE-54G (Wireless Range Expander) units at work and they have performed well over several years now:
http://www.amazon.com/Cisco-Linksys-.../dp/B00021XIJW
- Brian
Share the Road
Old 10-21-2010, 02:26 AM   #4
FSANE
FSANE's Avatar
the thing is that his cisco router does not have any antennas sticking out. everything is internal
looks like this
11.13 sec vid
BurnOut Vid
Old 10-21-2010, 02:26 AM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
The thing about extending his signal will be that you will end up purchasing something that you will have to bring with you and have him plug in while you are there. The above mentioned solution is a pretty solid one however you will be spending around a C note. It would be your best bet though. Be aware however that if you see that there are several wireless networks around the above mentioned box could NOT work because it auto configures and if for some reason it sees other networks it could either become confused or extend a neighbor's signal rather than your friend's. I have experienced that helping out a few friends in college dorms trying to LAN party across a building. I know that it might sound silly however if you are not there for long periods of time what would be the possibility of purchasing a 50 or 100 ft cat 5 cable and slinging it via the balcony to each other just for that time period? You didn't actually say if your friend is either directly or close to directly below you? It might sound pretty ghetto, but if you keep the cable tight outside of the building and route it correctly in the building then I don't see how it is a big deal? The other option would be to pick up an actual Access Point or Bridge. This would connect via a cable to your friend's router and be configurable specifically to his/her network.
http://www.newegg.com/Product/Produc...82E16833124012
This is in the same price range as the extenders.
Old 10-21-2010, 03:07 AM   #6
chrisj
chrisj's Avatar
Exactly the one I gave a link for!
Old 10-21-2010, 02:16 PM   #7
FSANE
FSANE's Avatar
ok just ordered
for $21.99 (ref)
and
booster antenna just in case.
for $7.99
11.13 sec vid
BurnOut Vid
Old 10-21-2010, 02:48 PM   #8
chrisj
chrisj's Avatar
^ Sweet. That should do it.
Old 10-21-2010, 02:55 PM   #9
fnkngrv
fnkngrv's Avatar
have you ever installed one of those where there are several wifi signals overlapping each other?
Old 10-21-2010, 03:11 PM   #10
chrisj
chrisj's Avatar
^ No. Signals I had were all from one router in the same hotel. I used to be contracted to install WiFi in various hotels in my region, but the signal was always from one source. I see what you mean though, being in an apartment building. Surely it can be locked into just one source...the strongest?
looking for advice from home theater gurus! TinyGiant Off-topic / Other Cars / Everything else Discussions 0 12-08-2009 11:23 PM
Technical Question for the Suspension Gurus KwonSau Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-21-2007 11:31 PM
Any electronics gurus in here? ponieswhee In Car Entertainment + Electronics (audio / video / alarm) 4 05-21-2007 08:42 PM
