09-08-2024, 11:33 AM | #1 |
Drives: Yaris T-Sport '01 Join Date: May 2015
Crank no start 01 Yaris Ts
Hi all, been a while but hoping someone can help me dive into this issue.
Couple years back had a minor incident with a crash barrier that mangled my hood and radiator support. Chassis is fine and found replacements for the rest. While I had the space in the engine room I swapped the engine (1nz-fe) as mine was using buckets of oil. After swapping engines gave the replacement a small service with oil, filter and plugs but engine ran very rough. Misfiring on cil 1. Switched coils from previous good running engine but problem remained. Have a bluetooth obd scanner but didn’t get any codes or useful information so tried my luck with a vci plug. Never got it to work, but now some weird issues remain.(yes, lesson learned on copies) - The cluster no longer displays the mileage unless the vci plug is in place - Engine cranks fine but wont run at all anymore… - After cranking the needles start dancing, only stopping after removing key - key “on” position doesn’t show cel So with the vci plug in place all looks fine, starts still but wont fire anyway. Things I’ve tried: - spray some brakecleaner to see if it runs, no luck - checked all fuses, efi, am2, etc all good - Have another Yaris, same year, engine etc and switched over ecu, key and cluster and was running fine so those components are good, thankfully ecu not fried I’d say maybe I fried the obd port or something, but how does one check that? Cant seem to find wiring or pinout info for this ecu (Fujitsu 89661-52230 mt) |
09-09-2024, 03:11 AM | #2 |
I suppose the "new" engine came from a reliable source and was working just fine in the previous car. Using engine from some totaled car would be unwise.
I am just thinking if we need to locate a problem caused by engine swapping or if we can consider the swapping done fine and it is all about a problem that came inside the "new" engine. |
10-02-2024, 02:36 AM | #3 |
Drives: Toyota Yaris 2020 Join Date: Oct 2024
A thobe conveys respect for cultural heritage while ensuring comfort throughout the event. Choose a well-fitted omani thobes in uk to truly express your personal style. Thobes are designed for comfort, allowing ease of movement during various occasions.
10-03-2024, 03:15 AM | #4 |
Due to their symbolic significance and beauty cross chains are more than just fashion accessories they can be cherished cheap engagement rings keepsakes passed down through generations, adding an emotional layer to their aesthetic appeal.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 08:50 AM |
yaris won't start, engine truns over but won't start. | zara616 | General Yaris / Vitz Discussion | 16 | 09-05-2021 12:39 PM |
2018 Yaris SE 5MT - T-Sport w/Valvematic! | atomic_hoji | Performance Modifications | 130 | 02-23-2019 12:56 PM |
Yaris Wont Start | magnum555 | DIY / Maintenance / Service | 0 | 10-29-2017 06:30 AM |
09 Yaris No Start | dieselphreak | DIY / Maintenance / Service | 47 | 03-16-2015 12:36 PM |
