Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Australia
Old 08-03-2018, 11:52 PM   #1
Gezza
Drives: Yaris Ascent 2015
Angry Rattling/ knocking noise around 2-3000rpm
My Yaris is 3 years old. For the last two years I have heard a loud rattle sound, usually on a slight incline and around 2-4000rpm.
The dealership have ‘investigated’ but are continually unable to locate the noise. It is difficult to pinpoint the location of the sound. It’s potentially from the other side of the driver’s footwell or coming from low down within the centre console.
Is this common ? How have others rectified this?
Gezza is offline   Reply With Quote
Old 08-04-2018, 02:05 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Probably a loose exhaust shield vibrating against something, a fairly common issue with these cars. If so its nothing to worry about. Crawl under the car and investigate. You should be able to bend / adjust the shield so that it is not hitting anything.
Old 08-05-2018, 05:25 AM   #3
Gezza
Thanks NYC
Tags
acceleration, noise, rattles
RATTLING NOISE EXHAUST PIPE/BACK OF ENGINE joeljcruz86 DIY / Maintenance / Service 15 09-13-2014 06:46 PM
Various problems with service at shop (green coolant and accelerator rattling noise) LilyOfTheYaris DIY / Maintenance / Service 4 04-08-2014 10:31 PM
bearing noise from 3000rpm yemfoo DIY / Maintenance / Service 2 09-28-2012 02:09 PM
AC makes a rattling noise when turned on. gabriel2012 DIY / Maintenance / Service 8 07-12-2011 06:03 PM
annoyin noise (ticking or rattling) on idle.. abdallah380 DIY / Maintenance / Service 2 04-18-2009 05:40 PM
