Old 06-07-2007, 09:11 PM   #1
antfeldsch
Drives: yaris
Amp Install on Factory HU
If I tap into the Left Rear speaker and connect to the high setting on amp will this work. I know where to run the power and a ground. But where will I get the turn on lead?
antfeldsch is offline   Reply With Quote
Old 06-08-2007, 02:42 AM   #2
BlueFlash
wa do dem
BlueFlash's Avatar
Drives: 2007 blue Lb
you mean the remote wire(the wire that turns on the amp) you run it to the acc. wire on the ignition so the amp powers up when the cars on or turned over to acc. and if you tap in to the speakers for signal you need a line out look thew this sectin of the forum if posted how tos on other threads on this subject and pic on one
BlueFlash is offline   Reply With Quote
Old 06-08-2007, 03:32 AM   #3
FlyingDevil
FlyingDevil's Avatar
Drives: 07 Corolla
well i just installed an amp and a 10" sub on my corolla with the stock HU.
what i did was, get an amp that has speaker-level inputs, so i didnt have to worry about buying RCA converters. i tapped into the rear right and left speakers for signal. and the turn-on lead or remote turn-on wire, i tapped that into the cig lighter cable. only problem is that when ever the car is on or key in acc the amp is on as well... so thats the only bad thing, is that it doesnt turn on with the HU, but the car... but that doesnt matter much since whenever the car is on, the radio is on aswell...
FlyingDevil is offline   Reply With Quote
Old 06-08-2007, 02:27 PM   #4
BlueFlash
wa do dem
BlueFlash's Avatar
well thats your only option with a factory hu unless you tap in to the hu power
Factory armrest install DIY. PetersRedYaris DIY / Maintenance / Service 16 07-27-2012 05:25 AM
Amp install under the passenger seat questions.. MudBug In Car Entertainment + Electronics (audio / video / alarm) 19 06-06-2007 11:12 AM
My Rant...arrrg....(amp install) hasher22 Off-topic / Other Cars / Everything else Discussions 3 05-12-2007 09:59 AM
small 4ch amp. 4x100rms ben dover In Car Entertainment + Electronics (audio / video / alarm) 2 04-08-2007 04:17 PM
Custom Sub Enclosure (inc sub, power cap, amp) wado Items for Sale by private party 3 09-18-2006 11:53 AM
