Old 08-26-2011, 05:23 PM   #1
Martin Terp
Drives: Toyota Yaris 1,4 D-4D 2005
Trackday - Yaris 1,4 D-4D 2005
Hello
I'm a newcomer to the wonderfull site - and just wanted to share my latest Trackday-video with you...
I've done som mods on the car - and it's pretty effective on the track now...
http://www.youtube.com/watch?v=s7JhEdPoolA
The track is "Padborg Park" here in Denmark, and my Yaris got a bigger turbo + remap of the ECU, Tein Basic coilover suspension, Whiteline rear swaybar, camber adjustment and 16" OZ Ultraleggeras.
I havent got any pictures with my new Ultraleggeras - but i've got these photos af the car with the OZ Supertourimo GT's.
It started like this:
And then I began modding the car a bit...
255mm brakes from a Yaris 1,5 T-Sport (RS) was a must
Tein Basic coilover
OMP frontseat
Turbosmart Eboost 2 boostcontroller
Mounted in the car
TRD bushes all around, Whiteline rear swaybar, TRD Underbody rear brace
The result:
The engine is now putting out 115 BHP/208 Nm @ 1,55 bar (boost), standard: 0,9 bar.
It's great fun now...
Martin Terp is offline   Reply With Quote
Old 08-26-2011, 08:37 PM   #2
great mods, nice spot for the eBoost (I've had that unit before, liked it).
Excellent! Sounds like you were being a little cautious with the throttle
Old 08-27-2011, 12:57 AM   #3
Martin Terp
Thanks!
Yes, the Eboost fits very nice in the dash - just had to make a adapterring, end make some cutting in the "ventilationhose" behind the dash.
The small diesel-engine revs to aproxx. 5.200 rpm, and 95% off the time, its full throttle on the track... So... Either the sound is to bad (its not great - I know) or your using a funny thing called irony...
Here we go again - but this time I take it a bit easy at first. We had a lot off oil on the track, and i'm the first to drive round, after the cleanup. Oil and tyres dosen't go well together...
http://www.youtube.com/watch?v=n1EGVVG6UU8
Old 08-27-2011, 07:59 AM   #4
eric_edge
Drives: '11 3dr white
oooooomg that looks like too much fun
got me thinking...
eric_edge is offline   Reply With Quote
Old 08-27-2011, 11:33 AM   #5
The 5200 rpm explains what I hear in the video, thanks for the clarification. (Our USDM rev limit is 6250).
Old 08-27-2011, 12:53 PM   #6
Mead
Drives: BSP Yaris LB 2007
Awesome
Mead is offline   Reply With Quote
Old 08-27-2011, 02:11 PM   #7
Martin Terp
Petrol-engines rev a bit higher that diesels...
Impressive result on your Yaris btw.
Old 08-27-2011, 11:26 PM   #8
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
i really like your car, very clean!
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-28-2011, 12:18 PM   #9
Cillian
Cillian's Avatar
Drives: Toyota Yaris XP9(f)
Sounds like you're rev'ing the diesel way to high. Mine is not producing much power above 4500 RPM, but i only got stock 2010 with 90HP and 205Nm and 6-gear manual. But it seems to work fine :D
Cillian is offline   Reply With Quote
Old 08-28-2011, 02:06 PM   #10
Martin Terp
Thanks for the kind response...
Mine is a 75HP (non-VNT-turbo), and the remap/turbo is a highreving combination. The new turbo is from a Toyota CT9 from a Toyota Starlet 1,3 GT Turbo (petrol) and was also used on the older 1,8 TD-engines (diesel).
The disadvantage is, that it takes a bit longer for the turbopressure to built up - but when it comes, it flyes away...
As you can see, I have 115HP from 4.000 rpm, and it drops to aproxx. 100HP at 5.000 rpm. When I change gear, the engine hits about 4.000 rpm again in the next gear, so I have a good powerband... If I keep the throttle in the floormats...
Old 09-08-2011, 02:00 PM   #11
yredgt
Drives: 1.5L SuperRed Yaris (TS)
Hey! your car looks great! impressive mods! I just have one question. Can you please tell me what is the part number or kit number of the TEIN coil-over kit you used? Is it the QSY14-CVAS2 kit? Thank you!
yredgt is offline   Reply With Quote
Old 09-09-2011, 02:42 AM   #12
Martin Terp
Thanks... :-)
I found this from the order confirmation:
QSY14-CVAS2:TEIN[1] TEIN DRIVING MASTER BASIC DAMPER-COILOVER KITS Driving Master Basic Damper Coilover Kit - YARIS 98-05 Toyota YARIS 98 to 05 NCP10
So yes - it's the same as you posted... :-)
Old 02-22-2012, 11:32 AM   #13
jo-vitz
Drives: Toyota Vitz RS
more pictures please...........
jo-vitz is offline   Reply With Quote
Old 02-24-2012, 12:47 AM   #14
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
good mods. very sharp
Club SHIFT
Old 04-10-2012, 04:07 PM   #15
jo-vitz
up to this topic.. very good
Old 08-16-2019, 10:52 PM   #16
Redflow2014
Redflow2014's Avatar
Drives: Yaris d4d
Fantastic, have you still got the car?
Would love to know more. I’m thinking about doing my d4d up a bit.
Redflow2014 is offline   Reply With Quote
Strut mounts/caps 2005 Yaris dwoodpub General Yaris / Vitz Discussion 8 12-27-2010 10:44 PM
2007 Yaris Unveiled at 2005 SEMA Show YarisBueller General Yaris / Vitz Discussion 0 01-12-2006 05:28 PM
