Old 04-17-2007, 12:36 PM   #1
aephilli
Drives: 2007 yaris hatchback
Oil use
Reading the owner's manual, it says 1 litre of oil loss per 1000 kilometres is acceptable. So, if my car burns a quart of oil every 600 miles, toyota says that is within specs??????
aephilli is offline   Reply With Quote
Old 04-17-2007, 01:07 PM   #2
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
your oil filter must not be on tight or you have two oil gaskets on there or you have some debris and the gasket is not sealing properly.
Go4th is offline   Reply With Quote
Old 04-17-2007, 01:37 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Yes, thats' correct. Every engine burns at least some oil. It's inevitable not to being that it coats the cylinder walls, valve stems, etc. One reason it is important to change your oil on time is that your engine always burns some oil, however the oil level remains the same because it becomes diluted with gasoline, moisture, etc. Don't worry, your car will probably never burn anywhere near that amount.
PetersRedYaris is offline   Reply With Quote
Old 04-18-2007, 07:52 AM   #4
aephilli
Sorry, Go4th, didn't mean to sound like mine is using, just that if it were using that much and toyota said it was within spec, I'd be in jail for going off on 'em. Back in the old days, when cars lasting 100,000 miles were long lived ('50s and '60s), a quart in 3000 miles between oil changes was usually considered to be the maximum acceptable use.
And Peter, the dealer better hope it never does, he's staking his gonads on it.
Old 04-18-2007, 09:23 AM   #5
Yaris Revenge
GIGA...DRILL...BREAKER!!!
Yaris Revenge's Avatar
Drives: Lagann. ;P
I'm really surprised they would state that. Yes, the chances of it happening are terribly small, but anyone with common sense knows that's an absurd amount to be burning. You're car would be puffing smoke like crazy at that rate (I know, I drove an S-10 Blazer that burned through a quart a month, and I could fog an intersection). For Toyota to claim that's "within spec" is moronic.
~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
Yaris Revenge is offline   Reply With Quote
Old 04-20-2007, 08:21 AM   #6
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Maybe you were looking at the 2 Cycle Yaris engine option. hehe
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 05-10-2007, 12:46 PM   #7
aephilli
THAT would explain it!!!!
"Dang li'l ol' thang do kindy favor one o' them old hondas, what had thet motorsickle motor in 'em, right, bubba?"
Old 05-17-2007, 04:52 PM   #8
jmjonesey
jmjonesey's Avatar
Drives: Red 2007 Yaris Sedan
Send a message via AIM to jmjonesey
~YR
I have a gmc jimmy that burns a quart of oil to go around the block
jmjonesey is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
