09-13-2010, 05:12 AM | #1 |
Drives: Decepticon - Ravage Join Date: Nov 2008
Bumping up my thread cuz its already filled with so much Ecometer info.
I have proven at least one so far that, the Ecometer is accurate to 0.002% (too high) on stock intake. On the AFE dry filter type 2 short ram it was consistenly ~10% too high AND using more fuel. On my latest fill up (10.119gal/last bar blinking), i got 34.2mpg Reading / 34.12mpg actual Compared with AFE ~35.6mpg Reading / 32.7mpg actual I never touched the eco-meter settings. so the only thing changed is the airbox replaced, one thing to note is i ran these two tests on stock size tires, the 185-60-15 flavor, reset ECU, cleaned MAF sensor with MAF cleaner spray, mix of Neutral/DFCO. Ironic enough I also drove much more spirited on the stock box, and dropped .4mpg cuz i idled to power my sub when i was doing some settings. I have no idea why the eco-meter reads higher value than actual with more air, which should equate to more fuel burned. So there you have it, stock air box/TIRES = perfect accuracy. Ill do another tank on stock box, to prove without a doubt. Tho it sucks to roll on steelies...
Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
09-13-2010, 11:36 AM | #2 | |
