Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > UK
Old 01-05-2022, 10:06 AM   #1
Tambzy
Drives: Toyota yaris
Cylinder 1 misfiring
I had the engine management light come on when going to top my car up I put my obd checker on it and it found 1 fault which said it was cylinder 1 misfiring can a yone advice me what this could be plz
Tambzy is offline   Reply With Quote
Old 01-05-2022, 10:50 AM   #2
It could be a fuel injector, spark plug, or a one-time hiccup. Clear the code and wait to see if it comes back on. If yes and the code is the same, swap the injector from the cylinder indicated with the one from another cylinder. Clear the code and see what happens. If code comes back, but for the cylinder that the suspect injector now resides in, then you know injector is faulty. If code has recurred for the original cylinder, the perform the same exercise with the spark plug.
Clutch Master & Slave Cylinder duendeverde DIY / Maintenance / Service 9 03-28-2016 05:31 PM
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Canada Only - Maybe a $1000 enviro rebate on Yaris> MDF New YARIS Purchase Forum 45 05-01-2007 08:17 PM
