Old 06-03-2007, 08:56 AM   #1
grampi
Drives: Corolla
Tire diameter list
Since a lot of folks are interested in going with "plus" size tires and wheels, I thought I'd post the overall diameter of some of the more popular sizes, along with the OEM sizes.
OEM
175/65/14 = 22.92"
185/60/15 = 23.7"
Plus sizes
195/50/16 = 23.64"
205/45/16 = 23.23"
205/50/16 = 24.03"
205/45/17 = 24.23"
205/40/17 = 23.43"
What has me a bit puzzled is the disparity between the two OEM sizes. That's .8" difference in overall diameter, which is quite a bit. You'd think Toyota would've wanted those two numbers a bit closer together.
I have narrowed my chioces down to to either 16" or 17" wheels. If I go with 16s, my tire size will probably be 205/45/16. If I go with 17s, my tire size will probably be 205/40/17. I was also considering 195s until I saw what a poor selection of tires are available in that size. The best selection is in the 205 size.
I haven't decided between 16s or 17s, and I really don't know what factors are going to help me with this decision. The number of tire chioces are roughly the same in both sizes. I may be leaning toward the 16s as their somewhat taller sidewall may offer a bit smoother ride, but am I really going to be able to tell the difference between a 45 and a 40 series tire in terms of ride comfort? Both have very short and stiff sidewalls.
If anyone would like to do their own figuring, here's the formula:
tire width * aspect ratio * 2 / 2550 + wheel diameter = overall diameter
or
205 * 45 * 2 / 2550 + 16 = 23.23"
grampi is offline   Reply With Quote
Old 06-03-2007, 09:47 AM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
yes
SPONSORED BY
Old 06-03-2007, 11:02 AM   #3
grampi
Drives: Corolla
yes
Care to expound a bit?
Old 06-03-2007, 11:12 AM   #4
SailDesign
Drives: .
or
Make that 2540, not 2550, so the final diamater is 23.26", and you've nailed it!
Or - just use the spreadsheet to compare sizes
Old 06-03-2007, 11:25 AM   #5
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Or check out the first couple posts of the Official Tire guide... this has been talked about.
2006 Red Blitzed RS 5-door
Old 06-03-2007, 12:27 PM   #6
brickhardmeat
Lonesome Cowboy
yeah see the official tire guide
and you -will- feel a difference from 45 down to 40
I'm very please with a 205/50/15
I also like using this for comparisons ...http://www.miata.net/garage/tirecalc.html
SPONSORED BY
Old 06-03-2007, 12:29 PM   #7
grampi
Drives: Corolla
According to this it's 2550:
http://oly4x4.com/metrictireconv.htm
Old 06-04-2007, 04:03 AM   #8
grasshopper
Drives: 2007 VW GTI
Sail is right. 1 inch = 25.4mm. so the height formula should use 2540. But, 3/100" discrepency is nothing to cry about.
grasshopper is offline   Reply With Quote
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
All season or Summer tire? GabL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 03-10-2007 11:07 AM
Yarisworld Parts List - Work in progress vodkalush General Yaris / Vitz Discussion 5 02-13-2007 06:12 PM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
