Old 09-16-2022, 08:23 PM   #1
NewYarisOwner
Drives: 2007 2DR Hatch
O7 Base Auto Hatchback Cruise no work & fogs install
I had had a tech install the full aftermarket cruise control kit in my Yaris and it will not work. I know our cluster has no light for it I tried it over 60mph and nothing. It's the full bolt on kit with the wiring harness and everything. What else can the tech check because I don't know.
Also is there a diagram for aftermark fog light install for my model or a wiring diagram for it so I can get them installed the eBay kit I had came with zero directions.
NewYarisOwner is offline   Reply With Quote
Old 09-22-2022, 03:37 PM   #2
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
As far as the cruise control is concerned I dont have anything to contribute, however with the fog light install, I can give you the resources I used to modify the wire loom as well as do my install. I did end up buying the fog light stalk from autozone so I didn't use the switch that came with my aftermarket fogs.
Send me your email address in a private message and I will send you what I have.
TommyWasabi is offline   Reply With Quote
Old 10-14-2022, 07:47 AM   #3
KelisDe
Drives: Yaris
can you share a link?
KelisDe is offline   Reply With Quote
Old 10-14-2022, 10:22 AM   #4
Neinris
I installed the cruise control myself to my DeeDee. I followed this video:
https://www.youtube.com/watch?v=nxRHFkUwg60
Old 10-20-2022, 05:33 PM   #5
sh0rtlife
the cruis is SIMPLE with OE parts..if you got an aftermarket kit your going to need to contact the manufactur3er and get them to figure it out
id send it back and go OE...the oe is a stupid simple and cheep install, grab the stalk from most any similar year toyota, grab the steeringwheel back cover from the dealer, and youll need the 2 wire from the same car you pull the unit, then run 1 wire to the ECU ...DONE
HELP Aux input install in canadian 2008 hatchback jack.duno In Car Entertainment + Electronics (audio / video / alarm) 3 04-17-2022 01:00 PM
Which of These Car Companies Will Go Bust First? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 23 11-16-2008 10:50 PM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd Bounty Hunter General Yaris / Vitz Discussion 7 07-11-2007 07:40 AM
Install sedan integrated stereo in hatchback? atebit In Car Entertainment + Electronics (audio / video / alarm) 6 05-22-2007 05:25 PM
