01-28-2009, 11:50 AM | #1 |
215/45/17 on stock suspention ,want to verify
Hey guys,
Finally getting some new wheels for my '07 Sedan Looking at some 17" but im thinking of running 215/45/17 Nankang tires I Dont see those measurements on the list in the guide All Input welcome and appreciated |
01-28-2009, 11:50 AM | #2 |
toyota
its good!
01-28-2009, 11:52 AM | #3 | |
Start another Oil Thread!
most likely rub, depending on your offset
01-28-2009, 11:59 AM | #4 |
ok so more info needed??These are the Wheels Evoke 17 x 7 +40 offset
01-28-2009, 12:03 PM | #5 | |
wow, $350 shipped for 4 new 17" wheels?
hmmmmmmmmmmmm (where's Russel teh Pirate???) maybe try 205 45 17?
01-28-2009, 12:04 PM | #6 |
so you think 215 will rub?
01-28-2009, 12:08 PM | #7 | |
01-28-2009, 12:12 PM | #8 |
im thinking of 215 cuz i like the wider tire
01-28-2009, 12:13 PM | #9 |
215/45/17's on stock suspension should work okay, but you may get a little rub up front lock to lock. Problem is, they'll poke out up front on ET40 and won't look like a proper fitment. I'd stick with OEM size 205/45/17.
01-28-2009, 01:15 PM | #10 |
ET40??
01-28-2009, 01:37 PM | #11 |
You indicated an offset of +40mm.
01-28-2009, 02:14 PM | #12 |
Gotcha ;)
01-28-2009, 03:16 PM | #13 |
Drives: 2008 Yaris Sedan Join Date: Oct 2008
the higher the offset the less chance of rubbing. +43mm is the minimum offset to run in these cars to prevent rubbing lock-to-lock, over bumps, or on lowered suspension. I'm on a quest the find the lightest wheels that are +43mm or higher in 16x7.
01-28-2009, 03:39 PM | #14 | ||
and in the grand scheme of things, does 3mm really make THAT much difference?
01-28-2009, 06:00 PM | #15 |
Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
I have 17x7" with an offset of +40, and 205/40/17 tires. I'm lowered on S.Tech springs, and get minimal rub on freeway dips. I don't get lock-to-lock rub tho, which is strange, but I'm not complaining.
01-28-2009, 06:06 PM | #16 | |
With 205/50/16 rubber, you can generally run +42 safely with no up-front poke and no rubbing. With 195/50/16, you're generally safe with +38. To answer Tamago's question: Yes, a couple of mm's makes a significant difference on these cars. |
01-28-2009, 06:26 PM | #17 |
toyota
what about 205/50/16 +40...trd dropped...
01-28-2009, 07:36 PM | #18 |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
I can't see 215-45-17 fitting... That's way-oversized for the Yaris!
Similar Threads | ||||
Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 12:30 PM |
