Old 08-21-2022, 06:49 PM   #19
TommyWasabi
Drives: 2007 Yaris 3dr
Originally Posted by sh0rtlife View Post
ok so it looks like the fog stalk is a 3 wire unit an the 3rd wire needs to be grounded i honestly ran it to the first bolt i could find with the column covers off...cant say i remember where exactly but i didnt run it very far
Ok, I got into it today and did the full install. I didn't have to do any wiring on the inside of the car because I modded the wire loom that came with my AM fogs and they came on with no problem. Additionally, the Duralast stalk from Autozone worked just fine.
I'm thinking that because you have both the console switch and the stalk switch, that might have something to do with the need for the additional ground.
I have working fog lights now!!!
TommyWasabi is offline   Reply With Quote
Old 08-23-2022, 10:15 PM   #20
sh0rtlife
i got my stalk out of pakistan so its probabably something about being a "euro" LHD stalk?....not sure, heck maybe the duralast just grounds that bit internaly for dual ground points..wouldnt be the first time ive seen aftermarket parts "shorten" the need for grounds internaly
my console switch needed a re-wire on the relay side to have them work together but that aside the ground was specific to the stalk i used
Old 08-24-2022, 10:24 AM   #21
TommyWasabi
Interesting. Yeah, I was able to find a LHD from Lithuania on eBay, but I didn't want to wait so long on shipping so I went with the Duralast one. I'm glad you got your fogs working and so far I am really enjoying mine.
Old 08-24-2022, 10:42 PM   #22
sh0rtlife
im curious if the switches work the same....when i turn the headlights off it forces the fog section to turn and go off as well
Old 08-25-2022, 07:16 PM   #23
TommyWasabi
Mine does the same thing, when I turn off the headlights my fogs turn off too.
Old 10-05-2022, 06:28 PM   #24
brownnick
Drives: Luna
When you say "bitcoin otc trading" are you talking about the column wiring fantasy miniature game? Also where did you ground to, I haven't looked under the dash yet to find a good spot, I figured I would you first.
amazing, thanks to you both
regards
brownnick is offline   Reply With Quote
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
2004 Canadian Echo Hatchback Fog light Kit ( OEM Style ) mpcv2000 Cosmetic Modifications (Exterior/Interior) 26 04-06-2017 01:25 PM
Driver side reverse light power issue xdr3amx007 DIY / Maintenance / Service 1 03-22-2016 03:44 PM
OEM Fog Light Brackets? xavior686 Cosmetic Modifications (Exterior/Interior) 15 02-16-2014 01:04 PM
2012 Yaris LE Check Engine Light On/Eco Light Off 2012YarisLE DIY / Maintenance / Service 1 01-22-2014 12:29 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
