12-25-2008, 09:51 PM | #37 |
Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
I simply cannot understand not using the AC and being uncomfortable to save a minuscule amount of money on gas, ESPECIALLY with current prices at about $1.60 a gallon.
I drive about 350 miles a week and with current prices, it costs me only about $15 a week fueling the Yaris. Turning the AC off (although not using it right now in December of course), would save maybe $.50 a week. Um, what's the point especially when discomfort is the main result? Do we really need that extra piece of gum? |
12-26-2008, 11:10 AM | #38 | |
Drives: Yaris Sedan (auto) Join Date: Jun 2007
I'm sure I waste in areas which others can't understand, but whenever I learn how to lessen my areas of waste, I will try my best to put those more efficient methods into practice. For me, not using the A/C in the summer means a 15% improvement in FE and one extra day between visits to the pump. It's also my experience that if you willingly waste a little in one area you find it easier to waste on other little things and that over time can really add up. |
12-27-2008, 10:30 AM | #39 |
Drives: 08 Sedan Join Date: Oct 2008
It depends on where you live. In Texas, you must use the AC in the summer. Hell today its already 74 outside and its only 9:45 in the morning. So I'll be using the AC when I go to the Wal-Marts today!
07-11-2017, 04:33 AM | #40 |
Drives: yaris 2004 Join Date: Jul 2017
You could also only drive when it doesn't rain so you don't need wipers or, better, live up a hill so don't need to use the battery to start or for the first few hundred yards. And never drive at night in case you need to use the headlights (btw, I knew someone who did this - seriously)
Better still - sell your car and walk! |
07-11-2017, 05:19 PM | #41 |
Drives: Charcoal 2012 Yaris SE 5 Speed Join Date: May 2016
I don't know how y'all people get 45 mpg. I get around 34mpg with my 5 speed. I'm thinking y'all drive very slow??
07-11-2017, 08:19 PM | #42 |
I don't know why the @$&# this thread got woken up after 9 years.
07-11-2017, 09:17 PM | #43 |
Drives: 2007 2-door hatchback Join Date: Jul 2016
so what changed about hypermiling or sceh's 2004 Yaris in those 9 years?
08-25-2017, 11:03 AM | #44 |
Drives: 2007 Yaris Join Date: Aug 2017
I have to agree, the few pennies it costs to run A/C is way better than cooking to death or having to smell stinky cars around you in traffic. I won't even look at a car for purchase unless it has A/C.
2006 YARIS RS |
08-25-2017, 10:56 PM | #45 |
Drives: 07 Yaris Liftback Join Date: Nov 2010
Why not just turn on AC as you're going down steep hills while in gear? You're gonna need to keep tapping the brakes anyways to slow down, minus well use the drag created by the AC to slow you down.
09-07-2019, 09:25 PM | #46 | |
Drives: Toyota Belta 1.3, 2008, 3SZFE Join Date: Apr 2019
Sent from my vivo 1727 using Tapatalk |
02-16-2020, 06:11 PM | #47 |
Drives: 2012 Yaris L, 2020 Yaris LE HB Join Date: Jan 2013
I actually see very little difference in fuel consumption while using the AC. Really, spending a few US pennies to be comfortable, especially if you are in a hot climate, is not that big of an issue. Turn the AC on and pamper yourself. You deserve it for purchasing a Yaris in the first place.
09-23-2022, 11:34 PM | #48 |
Drives: toyota Yaris Join Date: Sep 2022
Using the A/C use 1 litre more per 100 kilometers.
Open the windows when driving under 80kph |
10-13-2022, 11:45 AM | #49 | |
Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
10-20-2022, 05:35 PM | #50 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
even at over 5$ a gal im happy i retrofitted the AC option and it gets used price gouged fuel be damnd
10-29-2022, 01:48 AM | #51 |
Drives: 2015 Yaris Join Date: Aug 2022
You will probably burn more fuel fluttering your throttle to try and stay right there than you will save by doing this. That truck driver is also gonna hate on you and you are reducing your own effective visibility at the same time.
10-31-2022, 09:51 AM | #52 |
Drives: yaris Join Date: Nov 2018
I have a scan gauge and idling/slow speeds with the ac on you will get a noticeable mpg drop. Once you are going and cruising its not much at all.
11-01-2022, 04:24 PM | #53 | |
someones going to spout shut off the car, yeah our AC systems suck to get "up to speed" but work really well once they are ahead of the heat curve/humidity..and the amount of time to re-cool and remove the humidity we had this summer..your at your next stop swetting bullets and the car has just started to cool again and your shutting it down..by the 3rd stop youve got enough engine heat soak into the cooler that you leave it running for the next 3 stops to "catch up" or you suffer the heat and shut it down entirely as its pumping more humidity into the car trying to play catchup all said if im delivering with the AC running full and idling at stops i noted a drop from my 27 to 25, while my wife who isnt as fast noted a drop down to around 27..Ie she would spend more time idleing than i would |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
Gas mileage and A/C | Chaad32 | General Yaris / Vitz Discussion | 18 | 01-29-2009 04:31 PM |
Help Needed: Unlink A/C to Defroster | stran | DIY / Maintenance / Service | 25 | 01-09-2009 01:50 PM |
A/C & Aftermarket intake | KSIbucky | DIY / Maintenance / Service | 2 | 03-26-2007 09:08 PM |
A/C smelling weird? | Yaris_PR | General Yaris / Vitz Discussion | 11 | 08-04-2006 08:26 AM |
