09-17-2012, 08:41 AM | #1 |
Drives: 2017 Yaris L (5sp manual) Join Date: Jun 2012
Coasting in neutral vs. DFCO?
I've been using DFCO as much as possible in my 2012 Yaris L (5-spd) as I realize it's an easy way to reduce some fuel consumption. I came across an ecomodder.com website that gives fuel-saving tips:
http://ecomodder.com/forum/EM-hyperm...ecodriving.php #44 on the list states that coasting in neutral (with engine idling) is a better option than coasting in DFCO mode. I was under the impression that DFCO was better than coasting in neutral? Any thoughts? Thanks. |
09-17-2012, 08:57 AM | #2 |
It's a juggling act using both DFCO and neutral to achieve best results.
If using DFCO slows you down too quickly and you end up needing to apply gas sooner than desired, then you've lost some of the gain.
09-17-2012, 01:01 PM | #3 |
Drives: 2009, auto, 4dr LB Join Date: Nov 2010
If I had a 5 speed I'd be tempted to bump that thing into neutral every chance I got. Since I have the auto I'll stick with DFCO.
My car before my Yaris was a 1988 honda Accord LXI 5 speed, and I could squeeze 36 mpg in the summer 32 mpg winter. The gas tank was 15.9 gl. Which put its range out past 550 miles in the summer. I think that car spent more time in neutral than in gear. Of course that was an 80's car, no DFCO. |
09-17-2012, 06:49 PM | #4 |
Drives: Toyota Yaris LE HB 2008 Join Date: Apr 2012
if you put it in neutral with automatic transm. would it be ok to change it to Drive while moving ?
09-17-2012, 09:00 PM | #5 | |
Drives: 2020 Corolla Join Date: Apr 2012
If I had an automatic transmission .. I would take my foot off the gas and use DFCO as much as I could but leave the car in gear to lessen the wear on the transmission. |
09-18-2012, 01:40 AM | #6 | |
play every day
I don't coast in neutral with my stick because when the engine is idling it's still using gas, whereas coasting in gear raises the engine rpms above idle and activates the DFCO. Then it doesn't matter how fast the engine is turning because it's not using any gas anyways. Just stick it in 5th and put both feet on the floorboard. |
09-18-2012, 10:40 AM | #7 |
Thanks everyone. I think I'll just continue to use DFCO vs. putting it in neutral while coasting.
09-18-2012, 01:59 PM | #8 |
Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
Unless I'm planning on slowing down or coming to a stop, I prefer to neutral coast. It has given me the best MPG results.
Similar Threads | ||||
Using DFCO to increase your MPG | BailOut | Fuel Economy Forum | 216 | 08-30-2018 04:15 AM |
Kinetics, coasting, and you | sbergman27 | Fuel Economy Forum | 18 | 05-08-2010 01:25 PM |
Coasting in neutral | bankrobber | Fuel Economy Forum | 9 | 03-11-2010 03:55 PM |
2004 yaris hatch, 2nz-fe, DFCO in all gears? | toyo | Fuel Economy Forum | 11 | 06-26-2009 02:21 PM |
So Close!!!! | aclark246 | Fuel Economy Forum | 13 | 06-07-2009 10:02 AM |
