06-01-2009, 10:13 PM | #1 |
Not starting. Help!
My 2007 yairs latchback is not starting up. Every time i turn the key is hear this horrendous rapid-clicking/grinding, what is going on?
The sooner the help the better |
06-01-2009, 10:26 PM | #2 |
Sounds like your battery is dead. Have you tried jump-starting or charging the battery?
06-01-2009, 10:49 PM | #3 |
Haven't tried.. I have no idea where to have began. I tapped on the starter to see if that was the issue, tried unplugging and plugging the battery back in. Lights and music come on though. Could that still be the issue?
Thank you for the rapid response |
06-01-2009, 10:53 PM | #4 |
Yes , turn of radio and electric fan's , and try useing jumper cable's .
06-01-2009, 10:53 PM | #5 |
The battery is the most likely cause with your symptoms. Do the lights dim when you try to start it? Would you happen to have a voltmeter to measure the battery voltage?
If you know someone with jumper cables, that would be my first suggestion. |
06-01-2009, 10:55 PM | #6 |
Alright, thank you folks.
If you lived close to me I'd love to fix any computer issues you have. I'll keep an update. |
06-01-2009, 11:22 PM | #7 |
Until help arrives to diagnose the issue, yes the lights are dimming when starting, no voltmeter. If it was the starter, god forbid, would the "Check Engine" light come on?
06-01-2009, 11:32 PM | #8 |
Half a Bubble Off Plumb
It's a weak battery. If you have a friend with jumper cables, get it started and drive down to your friendly local car parts store. They'll swap the battery for you.
06-01-2009, 11:40 PM | #9 |
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
if it's manual and no jumper cable...u could ask ur friend for help to push start the car...
06-02-2009, 01:16 AM | #10 |
Drives: '08 5-door Join Date: Apr 2009
Could even be dirty cable ends. Try taking them off and giving them a good cleaning. You'll have to do this in any case, so it's not wasted effort.
06-02-2009, 02:58 AM | #11 |
Car runs. Had to change the battery. Thank you so kindly yaris forumers.
I ended up buying a battery that was a weee too tall for the bay, i had to take out the plastic holder from the bottom in order for it to fit... Hope i won't be needing that Last edited by Thedunpeal; 06-02-2009 at 04:29 AM. |
06-02-2009, 04:32 AM | #12 |
Captain Slow
Drives: '08 1.5 hatchback Join Date: Dec 2008
it just a battery holder,but make sure that your new battery sat still in it's place.
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA |
Similar Threads | ||||
Problems starting the engine | fmicle | General Yaris / Vitz Discussion | 10 | 10-07-2009 08:48 AM |
Starting Problems | oconna2 | General Yaris / Vitz Discussion | 16 | 12-10-2008 04:39 PM |
Fill up with Super before starting your boost project | LtNoogie | Forced Induction Forum | 5 | 12-01-2008 06:41 PM |
Starting Engine - Yaris Hatchback M/T | gbuks | General Yaris / Vitz Discussion | 2 | 11-06-2008 12:24 PM |
hard starting after moving car | gonzo452001 | DIY / Maintenance / Service | 12 | 06-09-2007 05:07 PM |
