Old 04-12-2007, 01:57 PM   #1
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
Question Spare tire still useable???
A friend of mine told me that after changing from stock(steelies) to bigger aftermarket rims (Konig Feathers 17x7) my sparetire is pretty much useless.
Is that true??? If so am I SOL when I get a flat?
eijikikimaru is offline   Reply With Quote
Old 04-12-2007, 01:59 PM   #2
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
Yea actually I like to know this myself so I can take the weight out of my trunk.
-- Blen
Old 04-12-2007, 02:05 PM   #3
i don't see why it would be useless, maybe you just have to be extra careful since the overall diameter of the Konig's are larger than the OEM steelies.
Old 04-12-2007, 02:20 PM   #4
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
It will be fine. Your friend is useless, not the spare.
Old 04-12-2007, 02:26 PM   #5
eijikikimaru
Q(','Q)
LoL Thanks a lot! I'll let my friend know that's he's useless too
Old 04-12-2007, 02:37 PM   #6
Blenjar
Blenjar's Avatar
Nice 1
-- Blen
Old 04-12-2007, 06:14 PM   #7
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
yeah, it is fine
i do wish a full size spare fit back there like in my Golf but the donut is fine, you won't be driving on it long anyway
SPONSORED BY
Old 04-12-2007, 06:54 PM   #8
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
May want to keep a set of stock lugs with your spare....something to check out if your new wheels got different types of lugs.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 04-12-2007, 07:07 PM   #9
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Don't forget it's best to put the spare on the rear. If you get a front flat, put a rear on the front, then replace the rear with the spare. You don't have to do this but it is better for your tranny.
PetersRedYaris is offline   Reply With Quote
Old 04-12-2007, 08:13 PM   #10
OK Yaris
Drives: 2007 Liftback
Exactly, and be sure to keep two socket sizes or two lug wrenches if the lug nuts are different sizes. I carry a breaker bar and socket for the lugs on my aftermarket rims, and left the stock lug wrench in the car for the spare tire lugs.
OK Yaris is offline   Reply With Quote
Old 04-12-2007, 09:04 PM   #11
If you've chose your aftermarket rms and tires wisely, and the overall diamter remains the same, or very close to the stock wheels, no problem.
Good point about keeping spare lugs as well, I'll have to check that myself, it would suck to not be able to attach the spare properly!
Old 04-12-2007, 09:47 PM   #12
Black Yaris
der Zeck
Black Yaris's Avatar
most tuner lugs used on aftermarket wheels work just as well as the stock lugs, so there is no need to keep the stock lugs in most cases, long as your aftermarket lugs have a bulge seat, and not a shank you will be fine... again it all depends if you had stock steelies or aluminum, cause Toyota uses shank lugs on aluminum wheels and bulge seats on steel
Old 04-13-2007, 09:02 AM   #13
largeorangefont
Break'em off some.
Good preventative info here. If you can, put the spare on the rear if you have a front flat tire, as it is better for the differential. If you can't don't worry about it too much.
If you have "tuner" style lugs they will work fine with the spare donut. Just make sure you have tht capability to REMOVE the tuner lugs in the event of a flat. I have splinedrive lugs and the key for them fits in the breaker bar that came in the tool bag.
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
All season or Summer tire? GabL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 03-10-2007 11:07 AM
Tire Fitment question Ryu Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 01-14-2007 01:47 AM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
