Old 03-13-2023, 05:05 AM   #1
blxebxrry
Drives: 2005 Scion xB
Do all 1nzfe cars have the same codes?
I've got a scion xB and it has the same engine as the Yaris the 1nzfe, you guys seem more active than the xB forums so I figured I'd ask if the codes are the same
P0442
P0420
P0441
P0446
we've narrowed it down to the evap purge valve but everything I was told to check checks out and nothing looks wrong with it, before I get a new one I wanted to ask here.
blxebxrry is offline   Reply With Quote
Old 03-13-2023, 01:31 PM   #2
Neinris
P0442
P0420
P0441
P0446
I replaced mine a couple of years ago or so when I was chasing some ghost faults (come to find out later that the ODB II reader I was using was bad). Then I used my buddy's fancy ODB II reader (tablet style), and if I remember correctly P0441, 442, and 446 where the only ones that showed up, which pointed to the evap purge valve. I was scratching my head, because I had just replaced it. I didn't want to spend another $70, so I bought one from EBay for $12 and the fault went away. Been trouble free since, and actually I just did my emissions check this past Saturday, and passed with flying colors!
Old 03-13-2023, 01:34 PM   #3
sh0rtlife
yes in fact most toyotas share codes
replace the purge valve thats mounted up on the intake pipe, 10-1 odds are its whats failed, clear the codes then go drive at 46-63 mph for 3-5 mins that should do the emissions readyness check and tell you if youve fixed it or not
honestly i grabbed a pair of used units for 5$ at a wrecker and tossed 1 on my XB-2 and it solved it...and it tossed that same stack of codes
Best / Worst Yaris Investments tk-421 General Yaris / Vitz Discussion 128 01-03-2024 03:41 PM
1NZFE - the most boring engine? SlowVitzRS Performance Modifications 25 05-21-2018 11:10 AM
Sponsors List RogueYaris Sponsors Classifieds Area 14 01-05-2013 10:23 PM
California May Ban Black Cars MadMax California 69 12-09-2009 10:44 PM
50 Ugliest Cars of the Past 50 Years KCALB SIRAY Off-topic / Other Cars / Everything else Discussions 56 11-07-2009 10:49 AM
