Old 08-01-2022, 11:33 PM   #19
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
That's like a low 12 second car. Phenomenal.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 08-02-2022, 12:53 AM   #20
sh0rtlife
imagine what it could do with a better gear set specificaly for the 1/8th
Old 10-16-2022, 01:28 PM   #21
Turbiini
Drives: 1983 carina 2NZ-FTE
https://youtu.be/PBN_acW3R6k
Turbiini is offline   Reply With Quote
Old 05-01-2023, 10:18 AM   #22
Turbiini
New clutch is slipping badly. In winter in did "maintenance" to engine so new bearings flywheel an clutch. flywheel is fidanza 133151 aluminium, disk is cerametallic 4 paddle and pressure plate was oe replacement sachs 3082727001. 3 gear up every time boost ramps up clutch slips. i then went local racingshop and buy sash racing engineering 883082999766 pressure plate (they said its best 215mm stock style pressure plate). it was quite easy to modify to fit yaris flywheel, same bolt pattern put aligning pins need new holes. Still slipping, i can't figure out why its slipping now. last race season slips some times when cold, second start was ok. Last sumer was same type disk stock flywheel and old stock pressure plate made by valeo. so only real change is flywheel.
Old 07-30-2023, 12:49 PM   #23
Turbiini
Latest quarter time engine have misfire, but still time was quite good
Old 07-31-2023, 04:39 PM   #24
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Wow that is unbelievably hard to read lol. Looks like a 12.09 @ 180km/h
2014 NCP131 5 Speed
Old 08-02-2023, 01:59 PM   #25
Turbiini
yes 12.098 here is dash cam video with data log from that pass.
https://youtu.be/SVZzq5JIK88
I have also making my newest (or oldest) car to little funner to drive.
Old 07-27-2024, 02:27 PM   #26
Turbiini
new record
Old 08-14-2024, 06:50 AM   #27
Turbiini
Little maintenance
Old 08-31-2024, 04:20 AM   #28
Turbiini
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-07-2012 12:37 AM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 04:13 AM
