Old 01-30-2023, 07:51 AM   #1
BennyLava
Drives: 1987 Silverado
What is a good quality seat cover?
Hi all, I'm looking for some good quality seat covers for two cars. I'm guessing that there's a good brand that will have quality covers for both cars.
Car 1: 2009 Toyota Yaris Sedan
Car 2: 2014 Toyota Camry Hybrid
Both of these cars would benefit greatly from some nice new seat covers, and I'm going to buy some. When it comes to seat covers, you can buy cheap stuff that looks bad, or you can buy nice stuff that looks good.
Anyone here know which ones are nice? Thank you
Old 01-30-2023, 11:55 AM   #2
sh0rtlife
imo if the seats are threadbear its time for seats...arguably the 09 is likely got enough miles on it that the seat foam needs more help than the seat skin
Old 01-31-2023, 05:15 AM   #3
BennyLava
Well in this case, the 09 already has new(er) foam. It's a retired work car with 226k miles on it, and at some point the driver's seat got worn out so we had a local shop replace the foam. The passenger seat and back seats weren't used much, and the foam is still good in those. But the factory seat cover was not replaced, and at this point it would benefit from new covers. You wouldn't just cover one seat, or there would be an obvious mismatch.
As for the 2014, it's seat foam is still ok. And in the event that it does finally wear out, these aftermarket covers could always be removed, then replaced once the foam was redone.
Old 01-31-2023, 01:51 PM   #4
remcafee
you can also buy new oem seat covers, remember that every single part on your toyota can be fixed
Old 01-31-2023, 08:19 PM   #5
Compeer
Drives: NCP90 TRD Yaris Manual
I just bought cotton seat covers off of Aliexpress lol, cheap and cheerful. My Toyota racing team yaris seats have a small rip in the drivers one, Don't think i can get a replacement cover of the TRD seats right?
Compeer is offline   Reply With Quote
Old 02-02-2023, 01:24 PM   #6
remcafee
you might be able too, could be backordered or discontinued, but its worth a try to call the dealer and ask
Old 02-02-2023, 06:41 PM   #7
bladesmith6
Drives: 2007 yaris HB
remcafee, show me how! i swear the only thing i could find was seat foam that MAY or MAY not come with the correct fabric for our year not even the parts guys could tell me for sure.
bladesmith6 is offline   Reply With Quote
Old 02-03-2023, 06:13 PM   #8
Neinris
Drives: 08 Yaris 3 Door Hatchback
I got these for Christmas. I need to dye the armrest black to match.
File Type: jpeg 569D9F54-C78C-4CEE-85E5-E0BF9D40B933.jpeg (296.9 KB, 74 views)
File Type: jpeg B7126956-90F6-407F-9883-46663266D49E.jpeg (285.2 KB, 76 views)
Neinris is offline   Reply With Quote
Old 02-05-2023, 11:48 AM   #9
sh0rtlife
see if they will et you order and find out...i recently pulled a drivers side seat apart at a wrecker just to see if it was a "skin on foam" or "skin sewn foam" and found that atleast with the one i pulled it was glued and sewn into the skin....i also verifyed that aside from a "notch" in one of the side clips and the adition of the carpet "flap" driver and passenger seat bottoms are otherwise exactly the same....so if one was inclined to notch and move the carpet flap driver and passenger skin/foam can be swapped
Old 02-10-2023, 08:05 AM   #10
BennyLava
Yes but some of the aftermarket covers will have a small layer of foam on the underside. This helps a bit if the seat is somewhat worn. Granted you should probably glue down some seat foam before you put on the cover, if this is the case. 1 layer of half inch or 3/8" thick seat foam would go a long way. It would make the cover look nicer and fit better too.
Unexpected Seat Belt Light Flashing ern-diz DIY / Maintenance / Service 19 09-23-2018 01:03 AM
DIY - Replacing the Front Seat Cushions CTScott DIY / Maintenance / Service 6 10-04-2016 06:39 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
Drivers seat - wire sticking through cover on back. azeeroth DIY / Maintenance / Service 1 03-30-2013 10:37 AM
