Old 05-31-2023, 09:24 AM   #1
nido539
Drives: Toyota Yaris 2006
Loss of Power in the middle of Driving after Car gets driven for an hour or more
Hi Folks,
I have got 2007 Toy Yaris 1.3L...Fot past few months, it is doing a weird thing...It starts well, runs well for a while and then in the middle of driving, it loses the Power and no matter how hard I press the Acceralator, The Car just drives at 5km/hour speed...Then If I wait for 10 minutes and restart the Car then it runs fine for some time until it repeats the same thing after a while.
Changed the Fuel Filter, Ignition Coils, Spark Plugs and MAF Sensor...But still the Car does the same loss of Power...
Did someone else had similar issue with Yaris in the past...If so, What do u think could be the culprit...?
Could it be a Bad Throttle Body which gets Stuck closed at the time of happening or Could it be the ECU as well...?
Thoughts ?
nido539 is offline   Reply With Quote
Old 05-31-2023, 11:49 AM   #2
sh0rtlife
verify your not losing fuel pump pressure
swapping out the TB would be a good idea as well
unless youve got an imobilizer i doubt the ecu is at fault
what codes is it throwing?...does the car have ABS/traction...some 07s do depending on market and if they get tripped via codes it goes into "limp in mode" and will do exactly as described...typical cause is o2 sensors
Old 05-31-2023, 03:49 PM   #3
bronsin
bronsin's Avatar
Sounds like it’s in limp home mood. They must be codes get a code reader. No check engine light?
Old 06-01-2023, 06:51 AM   #4
rayfloyd170
Drives: Yaris 2016 1.3 Manual
Originally Posted by nido539 View Post
Hi Folks,
Thoughts ?
if no codes thrown.. try changing 02 sensor Bank 1
rayfloyd170 is offline   Reply With Quote
Old 06-02-2023, 08:07 PM   #5
sh0rtlife
id second the upstream o2 as well...maybe codes just havnt popped for some reason
The Yaris Performance Primer eTiMaGo Performance Modifications 30 01-24-2024 04:26 AM
My car doesn't start yaristhebest General Yaris / Vitz Discussion 11 01-10-2013 10:02 PM
What Car Mechanics Don't Want You to Know!! daddz07 DIY / Maintenance / Service 16 04-17-2011 10:10 PM
How to Be a Street Racer - General Life Guide MDF Off-topic / Other Cars / Everything else Discussions 7 03-19-2007 12:49 PM
