09-11-2010, 03:45 PM | #1 |
Drives: 2007 Yaris Sedan 4 Door Join Date: Jun 2007
heat shield over manifold came loose, help?!?
2007 Yaris Sedan, the heat shield over the manifold in the engine area came loose and rattles on the exhaust, only like a cm or 2 free play but enough to rattle
The 2 bolts on top are fine and still solid but the bottom 2 bolts I see there, I can't figure it out, looks like they never held it down in the 1st place unless something else rusted off can anyone shed any light on this for me? thanks |
09-11-2010, 04:38 PM | #2 |
actually looks like 4 x 10mm bolts hold the shield down, is that correct?
09-11-2010, 05:45 PM | #3 |
^sounds about right
09-13-2010, 10:00 AM | #4 |
oh great, looks like the bottom 2 bolts are completely rusted and the metal bracket is completely gone, only 2 upper bolts held it, wonder if its ok to remove the shield altogether?
09-13-2010, 10:18 AM | #5 |
If you have some copper house wireing, you can strip it down so it's bare copper and tie it to manifold with that. It's better to have the heat shield left on.
09-13-2010, 10:33 AM | #6 |
thanks, I'll try that, can I pick up one of the bolts holding it at a local hardware store as I ruined one? lol
09-13-2010, 10:44 AM | #7 |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
it is OK to remove the shield
but if you get stuck in traffic on a hot day you could get some serious heat damage in the floor. best to get the heat shield fixed, or mcgyver your own. |
09-14-2010, 09:53 AM | #8 |
hmm, I can't find one of those bolts that hold the shield on for the life of me, hopefully I don't have to go to toyota for it :P
09-14-2010, 02:29 PM | #9 |
ok ok, finally found a bolt, lol.........plus gonna use a huge clamp to hold the bottom part on......damn rust
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
rear exhaust heat shield | Toy Yaris | DIY / Maintenance / Service | 7 | 04-19-2010 06:03 AM |
LEDs and heat | SaerinRhoe | Cosmetic Modifications (Exterior/Interior) | 10 | 01-02-2010 09:34 AM |
Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
General Warning and Fuel Tank Heat Shield | ttufrosty | General Yaris / Vitz Discussion | 8 | 05-31-2007 10:59 PM |
