Old 08-06-2012, 09:44 PM   #1
detroiter
detroiter's Avatar
Anyone taken off the intake resonantor tube?
Just wondering if anyone's done that? Has a nice little growl to it when under throttle :)
Old 08-07-2012, 02:08 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I'll bet there are a few people here who have done that...
When I ran my air box, I put a little velocity stack on it just for some bling...
One guy even flipped the whole box upside down and trimmed off the bottom so that the filter was completely open and facing up.
Old 09-11-2012, 06:41 PM   #3
bmxrider1189
Drives: 07 yaris hatch
I have a scangaugeII and I drove the car to get a baseline reading for the intake temp... it stayed around 70 degrees. Then i pulled over and removed that piece and drove again the same route and the intake temp rose to about 90 degrees. The sound was awesome without it but its sucking in much hotter air since the inlet is right behind the radiator.
bmxrider1189 is offline   Reply With Quote
Old 09-11-2012, 07:26 PM   #4
sex
sex's Avatar
Drives: 09 5DR
Would you guess you'd get better mileage as a result of the warmer air temp?
sex is offline   Reply With Quote
Old 09-12-2012, 11:54 AM   #5
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
mine has been off for a long time...during the winter i hook up a duct to the airbox that draws air from right off the exhaust manifold (well, its a header now) for better mileage
the only real restriction in the stock intake is the carbon filter...which i promptly removed a few days after i bought the car
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-12-2012, 04:18 PM   #6
detroiter
detroiter's Avatar
Carbon filter?
Old 09-12-2012, 04:26 PM   #7
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
It's in the "lid" of the air box, IIRC.
Old 09-12-2012, 05:48 PM   #8
detroiter
detroiter's Avatar
What does that thing do? Is that the one that's in the white "netting"?
Old 09-12-2012, 07:40 PM   #9
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It's a required item, part of the emissions control as well as "safety". As far as I know, it's illegal in most (if not all) states to tamper with it. That said, "any" restriction of the airflow will decrease engine output. =)
Old 09-12-2012, 08:49 PM   #10
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
i saw all of it as a waste and just put on a CAI instead :trollface:
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 09-12-2012, 09:38 PM   #11
malibuguy
Obsessed with 1.5L
Its there to neutralize the vapors that emit back out of the combustion chamber after the motor is turned off.
-96 Tercel 4dr
Old 09-12-2012, 10:13 PM   #12
detroiter
detroiter's Avatar
Anyone have a picture of it?
Old 09-13-2012, 07:04 AM   #13
sex
sex's Avatar
Drives: 09 5DR
http://yarisworld.com/forums/showthread.php?t=25941
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
Weapon R Dragon Intake yaris2010RS Items for Sale by private party 4 02-22-2012 03:05 PM
The great intake debate! fmicle General Yaris / Vitz Discussion 74 10-06-2009 11:37 PM
