Old 04-07-2007, 02:08 PM   #1
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
Exclamation Line Noise Problem
ok first off hi poeple. any and all help will be apretiated
Just got a new car, Toyota Yaris 2007 sedan
keeped the original stereo unit because its MP3/WMA and has an Aux input,
conected to the front out puts to LOC, then from there to an Audio Planet Preamp to split the signals; front, rear and subs.
from the preamp i have rca cable to the amps, 2 amps Power Acoustic one 4 channel 600w for front and rear, and one 2 channel 520w for the two 10" subs.
OK the stereo unit is grounded to its original place, the thingy that converts the wire is conected to where to preamp grounds, both amps are ground to bolt that hold down the rear seat. 2 of the rca calbes have ground wires, the ones that send the signal to the 4 channel amp, the sub rca cable doesnt have ground wire, the rca calbes that do are grounded to the block where the amps ground.. ok well that my set up,
the problem im having is noise in the system, basically everytime i excelerate you hear a high pitch whining sound, how can i eliminate this?
Arkhangel is offline   Reply With Quote
Old 04-09-2007, 02:22 PM   #2
Arkhangel
Arkhangel's Avatar
at the moment the power line is going down the left side of the car and the rca cables are going down the right but th remote line is with the rca's
and what am i looking for in the gorunds? cable gauge?
Whats best? same ground for everything, or grounding the parts in diferent locations to the chasys
Old 04-09-2007, 03:41 PM   #3
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
Some rca's actually run the remote turn on with the RCA cables because in theory they are both running to the back of the head unit...
If you ran them seperately I would say the next thing to look at is the grounds for the amps, make sure you picked a good ground...
Do a search and I am sure you will find multiple posts on where everyone grounded.........
Also make sure you check the pre amp, i tried hooking up a equalizer before and had tons of noise through it no matter where my ground was. Without it hooked up no problem whatsoever...
Just double check your connections, I am sure you will find something....
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Anyone Else having this problem???? MeggiemobileSFLA DIY / Maintenance / Service 3 03-01-2007 05:37 PM
Air Flow switch problem aucorium DIY / Maintenance / Service 5 01-15-2007 04:54 PM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
