![]() ![]() Drives: VERSO S Join Date: Jul 2021
YARIS 1.3 Vaccum from EVAP line
Gents
I had this strange issue in 1.3 petrol engine the evap line I can feel have a high pressure vacuum When I open the tank cap I feel hissing noise feel pressure released Is this normal I was looking at the evap purge valve which has one line from fuel tank evap this line has got vaccum in it and when I removed the finder the rpm increases this line connected to black pipe in the valve there is grey one from this valve which i believe goes into engine No codes. When I remove my finger from evap line the rpm increases and LTFT jumped to 9 Any help to test cross check would be highly appreciated |
Whenever I remove the tank cap I actually do not hear hissing. I hear clapping as there is negative pressure in the tank that sucks air from outside and I guess there is some protective shutter that that makes the clapping.
Driving Yaris 2007 hatchback with 2SZFE 1.3 engine. Bought it in 2012, always behaves like that, never threw a code, never had any problem with this. |
#3 | |
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Whenever I take the fuel cap off mine it always hisses as air rushes into the tank. I always assumed the EVAP system kept the tank under vacuum in order to draw petrol vapours from the tank into the intake to prevent them off gassing to atmosphere.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
2018 Yaris SE 5MT - T-Sport w/Valvematic! | atomic_hoji | Performance Modifications | 130 | 02-23-2019 11:56 AM |
Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 08:08 PM |
Which second hand Yaris to buy? 1.5-1.8 T Sport or 1.3 base? | REs | Third Gen Yaris General Discussion | 5 | 07-06-2011 04:08 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
