Old 12-03-2023, 03:03 PM   #1
digitron
Drives: Yaris P13
Yaris 2018 - new battery?
Hello everybody, my first post here :)
I have Yaris 2018 (NSP131L, 1,5 VVT-iE) and it has stock VARTA battery. Car runs fine, but today i've noticed that it took a few seconds more to start (cranks few seconds more than usual to start).
It's around zero Celsius here, and the car was parked outside for three days. I've noticed that last year during cold days, but this time it was significantly longer.
Later during the day after the car was parked for a few hours i took DMM and measured 12,19V while car was turned off. I took another DMM to verify readings, and the battery voltage was 11,95V. Car started almost normally (maybe 1-2 secs longer crank period than usual) and i took reading while the car was turned on. Voltage with headlights on was 13,9V which indicates that charging is OK. I could not measure voltage while starting because i was alone, and i didn't had long cables and clips.
Is it time to replace this battery due to voltage and age?
During last month the car was driven on short relations, maybe the battery just needs full charge?
If time is for replacement, is there any special attention to be made regarding computer? As i understood ECU will lose short-term memory, but i will drive car on open road (outside of the city) for 1 hour so the computer can record its parameters again. Is that OK?
many thanks for any comments!
digitron is offline   Reply With Quote
Old 12-03-2023, 04:45 PM   #2
ECU will only lose its memory if battery disconnected for a significantly longer period of time than it takes to just do a battery swap.
Old 12-03-2023, 09:52 PM   #3
Sharky808
4 Door Lover
Drives: 2009 Sedan
Resetting on battery disconnects is very minor these days. On certain cars the most you may have to do is a idle relearn or reprogram auto windows. These yaris are very minimum when it comes to technology so No change disconnecting battery won't have issues.
It's cold season now so you'll have harder times starting. There's multiple factors batteries and materials are so cheapy made and don't last like how they were years ago.
'13 Infiniti Q70 V8 (Fun machine for weekends only lol)
'01 Infiniti QX4 Camping Truck
'07 Yaris Sedan road tripper daily driver
'05 F150 for towing
Sharky808 is offline   Reply With Quote
Old 12-04-2023, 03:37 AM   #4
digitron
Drives: Yaris P13
Thanks! Given the voltage readings, should i replace the battery? Keep in mind, those readings were taken at 0 degree C (32F)
Old 12-04-2023, 04:51 PM   #5
komichal
Your battery can last a few more years.
But it can collapse in a week.
Nobody can guarantee you anything. There is no measurement device that would reveal when the battery will give up.
If the car is absolute must for you then get yourself a starterpack that can save you in critical conditions.
If you can survive one day by going by bus then do not get a starterpack.
You can change your battery as a preventive maintenance after some 2-3 years but again - even the new battery may not survive the first winter.
Old 12-07-2023, 09:12 PM   #6
Billiam
Drives: '10 White Yaris 4D LB
Generally speaking, once a battery reaches 5 years old there is certainly an argument for proactively replacing it. I just did that very thing with both of my kid's cars....a '19 Corolla and a '10 Yaris. I would rather replace an old battery before it strands someone.
If you want to enjoy your car, stay off of the internet.
Old 12-08-2023, 12:46 AM   #7
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
My 2014 still has the original Toyota battery it left the factory with
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 12-08-2023, 07:14 AM   #8
BLH
Drives: 2007 Yaris Sedan
My Panasonic battery.
Installed from the factory.
In my 2007 was 10 years old when I finally change it. Since it was getting questionable in the winter.
BLH is offline   Reply With Quote
Old 12-09-2023, 02:14 PM   #9
digitron
Drives: Yaris P13
At the end i decided to go with the new battery. Did the change already this morning. I've installed Exide 47Ah Premium with 3yrs of warranty (the original one was VARTA 45Ah).
Now i'm waiting tomorrow morning to check will engine still have long crank before starting
EDIT from the day after: It started like a brand new car :)
Tags
battery yaris 2018
2007 Yaris won't start - battery, starter, ignition switch okay quistis DIY / Maintenance / Service 9 07-05-2022 02:02 PM
battery size problem 2007 yaris clynam DIY / Maintenance / Service 7 12-20-2013 02:52 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 12:03 PM
