02-01-2021, 12:05 PM | #1 |
Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
Speed Accuracy...
The Yaris is said to have two different stock wheel/tire combo, the 175/65/R14s and 185/60/R15s. Currently I have 185/60/R15s, and my speedometer reading is off by 2MPH, where it reads 60MPH, when I'm actually going 62MPH. So I believe my car is dialed for the 175/65/R14 combo. It's kind of bothering me and want it fixed. Am I the only one having this issue? I don't want to go with smaller tires because currently the tire size I have fill my wheel well nicely. Is there a part number difference for the speed sensor that goes in the transmission?
02-02-2021, 12:08 PM | #2 |
Drives: Yaris T1 Join Date: Aug 2020
02-02-2021, 05:28 PM | #3 |
Drives: 2013 NCP130 Join Date: Nov 2015
Hmm, my speedometer reads faster that the actual speed.
Interestingly, If I take the output from the OBD port, it agrees with GPS speed. I wonder if anyone knows if it is possible to physically open the speedometer and adjust it?
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
02-03-2021, 11:07 AM | #4 | |
04-30-2022, 01:21 PM | #5 |
Drives: '09 Yaris carmine red 2d HB Join Date: Jun 2009
With my '09 HB The speedometer is dead on
This is according to all those solar powered speed read outs that a lot of towns use. When a readout says 30 MPH (in a 30 MPH zone) that is exactly what my speedometer says also. This is with 185/60/R15s tires as this is the size that came with it |
10-13-2022, 05:11 PM | #6 |
Eureka!!!
I discovered that there ARE two different part numbers for the speedometer driven gear sun-assembly!!!
One specifically states 185/60R15, I’m going to order it and install and see if that fixes my speed difference issue that’s bee driving me nuts for years!!! |
11-02-2022, 08:58 AM | #7 |
Is there a special tool to remove the speed sensor that's in the manual transmission? I couldn't get mine off to try and replace the gear sub-assembly. And yes, I removed the bolt that was holding it.
11-02-2022, 12:38 PM | #8 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
assuming its like all the rest ..its a very..VERY tight fit and just needs more effort..alot of them are a neer press on fit, you could always try tossing it in the freeze for a couple hours to shrink the metal its on
11-02-2022, 03:18 PM | #9 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
it should be sealed by an o ring, sometimes they fuse themselves to the case, just keep struggling, swearing, and fucking up your hands until its out lol
11-02-2022, 04:08 PM | #10 |
11-02-2022, 04:44 PM | #11 |
ah the actual sensor..is there room to get a carpenters blade under it?..ive used them as a puttyknife on things like that in the past to work them up just enought o actuly get a puttknife in there to work them more
Thread Tools | |
Display Modes | |
Similar Threads | ||||
DIY Cruise Control for 2012 Yaris - Good News! | CTScott | Third Gen Yaris General Discussion | 304 | 10-10-2023 05:23 AM |
Question on Radiator/AC Condenser fan speed | rayfloyd170 | Third Gen Yaris General Discussion | 3 | 08-11-2020 07:44 PM |
The most economical speed for the Yaris. | Ilovemyyaris | Fuel Economy Forum | 3 | 03-19-2012 11:33 AM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 05:31 PM |
