Old 10-15-2006, 09:07 PM   #1
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
Tire size
Hi, I'm getting snow tires for the Yaris, however, the brand I wanted doesn't come with 185/60/15, they only come with 185/65/15. Does that fit to the car? Will it create any problem? Thank you.
GabL is offline   Reply With Quote
Old 10-15-2006, 09:23 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
putting to large of a tire may cause some problems.... I would try 195-60-15 it is just a but larger, but much closer to stock and 185-65-15, and more common
Old 10-15-2006, 11:41 PM   #3
http://www.eunos.com/tirecalc
experiment with different sizes and see what would be a closest match with what's available locally
Old 10-17-2006, 09:12 AM   #4
GabL
I want JDM bumpers!
GabL's Avatar
I checked the tire size calculator already, which the 185/65/15 will gives you 3.1% difference in odometer reading over 185/60/15. Just want to know if this will cause a problem or it should be ok. Thanks.
Old 10-17-2006, 09:37 AM   #5
xtrred
Drives: 02 wrx wagon to 07 yaris sedan
[coming from an AWD Subaru] - Tire size was very important as the differentials were designed based on running a certain rolling radius. I'm not sure what negative mechanical effects it would have on our cars (if any, other than incorrect readings on the odometer, speedo, etc.)
Does anyone know if the increase or decrease in he radius has any affect on the ABS? I don't THINK so, but wanted to at least put it out there for discussion.
-M
xtrred is offline   Reply With Quote
Old 10-18-2006, 01:04 AM   #6
yuri2002
Drives: Yaris HB
I need help on deciding which winter tires to put on? My yaris came with 185/60-15 tire. However, the stock tire is also available in 175/65-14. I am confused whether they programmed the speedometer using the 15" or 14"?
yuri2002 is offline   Reply With Quote
tire shine casterqc Wash, Wax, Detailing, Exterior Repairs 20 11-24-2006 03:27 PM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
Bulb size (application) question. W.A.S.P Cosmetic Modifications (Exterior/Interior) 4 10-01-2006 02:21 AM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
