11-15-2010, 03:55 AM | #1 |
Drives: Toyota Vitz Join Date: Sep 2010
TURBO INSTALLED ON 1SZFE
Finally the project has been completed and turbo has been installed in my ride after very hard work and experiments.
Engine is 1szfe Turbo is Garrett T28 SSqv Bov Return line made for installing FPR 225cc injectors Top mount intercooler Battery has been shifted to trunk Hks Fcon Mini Hks Afa Boost i'm running is 8.4 Psi The car has been tuned through wideband and the AFR was 10.5 to 11 Pics are attached below |
11-15-2010, 05:31 AM | #2 |
What is the power your are making?
F\A is on the Spot
--------------------------------------------------- “Do or do not... there is no try.” |
11-15-2010, 07:22 AM | #3 |
Drives: "Burning It Down GTX2860RS XB" Join Date: Sep 2010
Thats a tiny intercooler. Won't be surprised if you dont get heat soaked. and with it's location I hope you have a hood to support it's off-side placement. Also looks like you got in a hurry towards the end of your project. not sure if all of this was well thought of before you placed things. Parts of it just look messy and not finalized. I think your intercooler size and placement will be an issue.
I'm not not knocking your efforts, I just think part of its not well thought through or finished looking. XBG |
11-15-2010, 10:07 AM | #4 |
Drives: 2005 Toyota Echo Join Date: Oct 2008
I see nothing wrong with your intercooler placement. Remember this motor is only a 1L. The IC is an ok size. Having one too large and more piping will only result in turbo lag. You're current setup looks fine. Keep up the good work.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
11-15-2010, 11:01 AM | #5 |
placement of that intercooler will be fine...............as long as you can get air into it. And i'd rather have a little lag than heat soak.
XBG |
11-15-2010, 12:38 PM | #6 |
thanks
if you people have noticed so i have installed a powerful fan just below the intercooler which clears the heat thing issue. As far as the performance is concerned so its going much better, we are having no dyno machines here but i think its making around 110 to 120 whp |
11-15-2010, 04:47 PM | #7 |
Only Happy When it Rains
wow, that is pretty cool, i wonder how much lighter your model is, compared to ours.
Colin Chapman disciple |
11-15-2010, 05:03 PM | #8 |
@ why
dude no idea |
11-15-2010, 05:34 PM | #9 |
Drives: 07 Yaris Turbo Join Date: May 2007
10.5 to 11 is a little rich!
11-15-2010, 08:11 PM | #10 |
I think your AFR is fine 10.5-11 really isn't that fat, better than running lean. If you were in 13's i'd say you were to rich but your number is very common. You could lean it out a little to 8.5-9 and still be safe but lets not detonate.
My one pet-peve clean up your pipping, Looks messy. Use more aluminum pipping and a weld bung for your BOV, V-Band if possible. Just looks like you ran out of time or patience. XBG |
11-15-2010, 08:13 PM | #11 | |
11-16-2010, 03:56 AM | #12 |
thanks for your comments and views
actually the thing is i'm first person who has installed turbo in yaris, few people have imported yaris which already have turbo kit in it , but i have been through many experiments thats why the work is lil messy, soon ill go for almunium piping so i could have a better look in engine bay. I had to do different experiments to make this project sucessfull, secondly as far as i think the AFR is ok another point which i'd like to share is that, car was not getting tuned by earlier , i used to disconnect o2 sensor so the car used to get rich, without boost like below 3000 it used to be very rich and as the turbo spools it used to be perfect, and if i used to run car with o2 sensor so it used to be lean all the time but like for 3 days i didnt disconnect the o2 sensor and used to do normal cruising but yesterday i made a try, i ran car with the o2 sensor the car was perfect, in all 3 gears it was perfectly awesome. i asked my tuner he said your car has been tuned automatically via o2 sensor. Later i made another bunk next to o2 sensor for checking the afr, the afr was 10.5 to 11, when i disconnected the wideband sensor from that bunk the car again was in old situation, was in lean with o2 sensor so now i have again closed that extra bunk in manifold which i made for checking afr and now o2 sensor is connected. So now my question is that will o2 sensor again tune my car automatically and control the fueling accordingly ? |
11-16-2010, 04:42 AM | #13 |
Drives: yaris1.33 Join Date: Jul 2010
hi man good work !!! really admire you !
11-16-2010, 07:23 AM | #14 |
Damn-it Cali your right "spent to much time in the sun" reverse what I said.
Brain-Fart XBG |
11-16-2010, 08:07 AM | #15 | ||
It's a ratio of Air:Fuel not Fuel:Air |
11-16-2010, 09:08 AM | #16 |
thx henry :)
11-16-2010, 10:17 AM | #17 | |
11-16-2010, 10:46 AM | #18 |
so you think 10.5 is rich ?
Similar Threads | ||||
Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
Plan to install hks turbo kit on 1szfe | Faraz_Shaikh | Forced Induction Forum | 5 | 10-19-2010 11:00 AM |
Greddy Turbo installed | Bluevitz-rs | Forced Induction Forum | 22 | 09-03-2010 10:51 AM |
Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 10:24 AM |
HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
