09-18-2009, 10:46 PM | #1 |
Drives: Toyota Vitz 2002 SR Join Date: Jan 2009
Help! Turbo my Vitz!
Im planing on making my vitz turbo, but i really dont want much modifications i have read that if you run 7-8 psi you dont need lot of modification, by now i see you will need:
TC Injectors Piping Turbo Manifold Oild and Water line anything else? |
09-18-2009, 11:30 PM | #2 |
JDM Fred
do research... not trying to put you down. It is very complicated and at the same time not that complicated. Look at all different kinds of forums on turbo builds and you'll get an idea of what mods you will need. I would suggest a 1.5 differential, a clutch, tach, oil pressure, water temp, wide band air/fuel, boost gauge & controller.
09-25-2009, 04:42 PM | #3 | |
Drives: 07 yaris hatch Join Date: Jul 2009
09-19-2009, 12:55 AM | #4 | |
Start another Oil Thread!
DPL Vitz, please PM me, i have a few parts that will get you on your way.
09-19-2009, 11:31 PM | #5 |
Just call me Ray, better?
listen 2 tamago if any one else!!
09-25-2009, 11:02 PM | #6 |
it would wear out quicker, but not 2 fast, unless you launch it every where im sure
09-26-2009, 01:14 AM | #7 |
JDM Fred
IMO spending the $300-400 for a stage 1 or 2 clutch is well worth it. In modding a car it's best to have steppingstones. First you can build minor breather mods (intake, exhaust), then suspension (coilovers, sway &strut bars), then power-train (pullies, flywheel, clutch, diff), then finally forced induction. I would honestly rather have a yaris with pullies, exhaust, intake,coilovers, sway bars, diff, clutch, and flywheel than a turbo yaris with none of that.
Again I point back to my friend who has a 260whp @ 8psi on a 05 civic hatch with just strut bars. NO diff, suspension, clutch, ect. He can only push the car while moving otherwise he wont grip and will sit in place destroying 1 tire. Remember a 05 civic hatch has about 125whp... so that's basically double whp. It's the same amount you would get with 8 psi on a yaris (80whp to 160whp) |
09-27-2009, 10:45 PM | #8 |
No one mentioned the computer in the car. Will it be ok for him? How much you gonna try to boost Dpl Vitz?
Similar Threads | ||||
HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
TRD Turbo Vitz | 田中秀樹 | Forced Induction Forum | 26 | 09-26-2007 03:07 PM |
Vitz RS Turbo or new Fit RS? | Hyde | General Yaris / Vitz Discussion | 29 | 09-10-2007 09:26 AM |
turbo vitz... | ri_espinosa | Central and South America | 6 | 07-24-2007 12:11 AM |
Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 08:45 PM |
