11-08-2009, 04:13 PM | #1 |
Drives: paseo 4age 20v blacktop Join Date: Nov 2009
4age bt turbo
ok i new here. i found this site by googoling blacktop turbo and finding the turboecho2005 echo project. now i want to know witch fuel management this guy was using to run his blacktop to 8.5 psi on stock internal, cause now my paseo need more power and i'm new in the toyota world i was from the obscure side of the force with a lot of honda swap and turbo project but now with my paseo 4age bt swap project i need advice to go fast in that turbo project.
i'm sorry for my bad english there is my paseo bt 20v and now my first toyota swap sorry for the purist http://www.youtube.com/watch?v=xhyT4gRz5Hg Last edited by chart45; 11-11-2009 at 04:37 PM. |
11-08-2009, 09:18 PM | #2 | |
Start another Oil Thread!
did you try to PM him?
11-08-2009, 11:33 PM | #3 |
Drives: 07 Yaris Turbo Join Date: May 2007
he was using MegaSquirt fuel management.
11-09-2009, 11:31 AM | #4 |
Who said Yaris was slow?
For a low boost application an economical option would be an AEM FIC.
Then again... the BT is not the best suited engine for force induction. 11:1 CR and skiny con rods. I would not suggest pushing more than 8 psi and that is with a very good tune. |
11-09-2009, 04:28 PM | #5 |
Drives: 2005 Toyota Echo Join Date: Oct 2008
That's me. 8.5 - 10psi won't be a problem. 11-14psi can be done with water injection which I plan on doing soon. Remember psi doesn't mean anything until you specify what turbo you are using. I am using a gt28 with a 60 a/r. Most importantly you need to have a rock solid tune. My car was tuned for almost 4 weeks to make sure everything was perfect.
Obviously you cant run 8.5 psi with stock internals and a gt30 turbo. And I was using megasquirt. 248hp to the front motor 255hp to the rear motor if you need any parts let me know. I work for turbinetech ;)
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
11-09-2009, 10:00 PM | #6 |
if i'm using megasquirt do they sell ecu patch harness or i will have to rewire everything cause i just finish to rewire the complet paseo and wich injector do you use??? the last turbo setup i did i was using a smt6 with 2 fuel rail the fisrt rail was the stock h22 345cc injector and the second one was the dsm 450cc injector so in full boost its about 795cc
thanks for help |
11-10-2009, 04:34 PM | #7 |
I sent you a PM
11-11-2009, 03:51 PM | #8 | |
11-11-2009, 04:36 PM | #9 |
where did you get your intake plenum to suit your turbo setup on the 4 itb
11-11-2009, 04:56 PM | #10 | |
11-12-2009, 12:40 PM | #11 |
Garm you're right it's a 64 a/r.
We put a turbo setup on my buddys Sentra spec v. Stock engine running 14psi on a t3/4 turbo. Just throw in a wide band and crank the boost. As long as you don't lean out you keep upping the boost. The intake plenum was made by turbine tech.
11-12-2009, 07:36 PM | #12 |
ok for the plenum i take a look to turbinetech and they got a lot of stock for suzuki but did not find any toy plenum do you have to make a special order??? now witch injector did you use i find out that i can use any toyota side feed injector.. i don't want to go more than 8psi so should i use the 3sgte 340cc supra 440cc or supra 550cc injector???
11-13-2009, 09:16 PM | #13 |
ok yesterday i leave a email to the turbinetech guy and they reply me with this
this is what you have ??? i was thinking about something like that Last edited by chart45; 11-14-2009 at 04:38 PM. |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 10:24 AM |
HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 12:30 PM |
delayed turbo project... | joey1320 | Forced Induction Forum | 8 | 09-26-2007 11:18 PM |
Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 08:45 PM |
