04-07-2019, 04:45 AM | #1 |
Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
Just a question with OBD2
i recently purchased this OBD2 code reader/scanner ELM327 bluetooth 4.0 - VGATE iCarPro from Ali Express
Link: https://www.aliexpress.com/item/Vgat...3d964c4dm3Zb46 Since my Yaris is the base sedan model and lacks the engine temp gauges and fuel consumption/distance displays I want to know if it is safe to use this device while driving and plugged in all the time in the OBD port? It says it has auto power off function and consume less than 3mA. on top of that i also need to know the engine performance hence i need this plugged in while driving let say for a day or two.. I need your feedback please.. Thanks |
04-07-2019, 06:03 AM | #2 |
Drives: 2013 NCP130 Join Date: Nov 2015
It won't hurt the Yaris use it while you are driving.
How safe it is depends on where you mount the display, and how distracting it is to look at all the information....
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
04-07-2019, 06:27 AM | #3 | |
Thanks man for the prompt reply, just as i was expecting there should be no problem at all... However some people in AMazon commented that i should not plug this at all time, i dont know what are they afraid of? That is the reason why i came to pop this question here for more clarity of the answer but glad you answered me immediately... |
04-07-2019, 08:54 AM | #4 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
I use an ultra gauge that I leave plugged into the obd II port all the time. As long as it is functioning properly it won't pull any amps with the ignition off.
If something goes wrong with it there is potential for it to draw amperage and drain your battery when the car is off. This is not likely as I believe the obd II port has no power unless the ignition is on.
No one ever wants to give a Yaris the point by... |
04-10-2019, 03:52 AM | #5 |
The OBD2 port is continuously powered. It isn't ignition switched. Depending on the device's power drain, and how long you leave it plugged in, you could flatten the car battery.
04-10-2019, 04:32 AM | #6 | |
it says <3mA when not in use... i guess this is very minimal but anyway I am not concerned of the power drain.. the issue i am concerned about is Safety- to the point that it affects the whole car while i am driving at high speed... some people say "it might" interfere with the ECU while i am driving or i dont know if thats possible??? scary things in my mind... but if anybody can tell me that it wont affect whatsoever then i would put it plug all the time... |
04-10-2019, 06:45 AM | #7 |
The ELM can reset some ECM error codes to turn off the Check Engine Light. It can read many different values such as engine temperatures, RPM, speed, fuel/air ratio, timing advance and so on. It cannot override the factory programming of the ECM. You can see many parameters of what the engine is doing, but can't use the ELM327 to modify thse values. It will not affect the performance in any way. Software such a Torque will basically allow you to have extra virtual engine instruments, and read diagnostic codes if there is a problem.
04-10-2019, 06:55 AM | #8 | |
04-10-2019, 12:48 PM | #9 | |
Sent from my CLT-L04 using Tapatalk |
04-10-2019, 01:47 PM | #10 |
3 Yaris and counting..
I have one of these bluetooth readers in my car. I leave town for work 5 days at a time. My battery has never died. However the little red light on the reader will still blink if the car is off. Does it draw power with the car off? Well, the light blinks. Is the obd port powered when the car is off? Well, the light blinks.
I have never unplugged it. I have never experienced anything that would indicate it's messing with my ecu.
04-10-2019, 01:49 PM | #11 | |
04-10-2019, 02:12 PM | #12 |
Drives: 2007 2-door hatchback Join Date: Jul 2016
OBDII bluetooth display
w/ a Bluetooth OBDII reader, what is doing the display?
04-10-2019, 02:45 PM | #13 |
I haven't tested every pin of the obd plug but my gauge has no power with ignition off
04-10-2019, 05:21 PM | #14 |
Most people use their smartphone, but id imagine anything you can load an app on, that has a screen and Bluetooth
04-10-2019, 07:13 PM | #15 |
Here is a picture of the OBD2 pinout. Note that +12 volts is "Always on".
04-17-2019, 05:55 AM | #16 |
I successfully used my OBD2 and i just plug it up without removing it, doesnt drain my battery that much (<2.7mA) as per the manual. It totally shuts off (red LED off) about 30minutes when not in use...
I used Torque and sometimes Dash Drive Smart App... I find Torque very good since i can customize the display/ parameters that i need to monitor...Dash Drive Smart is also an excellent tool that gives you the driving score at the end of each trip.. However i find that my Yaris doesnt have the data for OIL Temp.. It only has the Coolant Temp? Am i missing something or this is just the case with our Yaris, maybe cost saving???? Thanks |
04-18-2019, 06:06 PM | #17 |
The manufacturers decide what sensors they want to fit to a vehicle. This would usually be a set that allows the ECU to function properly. AFAIK the Yaris only has a switch type oil pressure sensor to control the warning light on the dashboard.
I doubt there would be a vehicle available tbat has every possible sensor available. All you can do is chose from what is available to display.
07-08-2019, 03:26 PM | #18 |
https://www.ebay.com/itm/ELM327-V1-5...72.m2749.l2649
Manufacturer Specifications: NX101 Pro OBD2 ELM327 V1.5 Bluetooth Car Adaptor Auto Diagnostic Scanner ELM327 is built with auto-sleep mode, after 30 min without communication, it will go in sleep mode. The sleep mode of our scanner is only 10mA, so there is no need to worry about leaving it in the car over night with plugging in. |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
OBD2 Scanner/App & more | Braingasim | DIY / Maintenance / Service | 11 | 03-22-2023 09:31 AM |
License Plate question | awebb005 | Cosmetic Modifications (Exterior/Interior) | 5 | 11-11-2014 08:28 AM |
Voltage regulator and Amperage question... | cr.chango | DIY / Maintenance / Service | 13 | 11-24-2009 12:59 PM |
ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
