View Poll Results: Is it work it? | |||
Yes | 2 | 6.67% | |
No | 28 | 93.33% | |
Voters: 30. You may not vote on this poll |
01-05-2013, 09:55 PM | #1 |
Drives: 08 Blazing Blue LB Join Date: Jul 2009
(Cheap from ebay) Magnetic Fuel Saver
Has anyone used one of these? If so do they really make any difference at all, or are they just a waste? I was just browsing on ebay and noticed these.
this is part of their description; 1) Powermag: Magnetic Fuel Saver can help engine to burn fuel more efficiently 2) Powermag: Magnetic Fuel Saver let your car run more miles per gallon 3) Powermag: Magnetic Fuel Saver will improve engine performance 4) Powermag: Magnetic Fuel Saver will reduce emissions 5) Powermag: Magnetic Fuel Saver will clean air Magnetic Fuel Saver gadgets increase combustion efficiency for a cleaner burning engine. This reduces harmful emissions while increasing engine performance. Benefits of Magnetic Fuel Saver 1) Save fuel, save $$, more MPG (miles per gallon ) 2) 50% reduction of carbon monoxide and hydrocarbons 3) Helps pass emission testing/smog check 4) High octane performance with lower octane fuel 5) Improved performance - quicker starts 6) Stops scale build-up and corrosion in engine 7) Reduced wear on O2 sensor and catalytic converter Any info is welcomed! Thanks in advance. |
01-05-2013, 09:59 PM | #2 |
やりすぎだ~
Are you talking about this one or something similar? Buy it! Doubles as a penis enhancer.
01-05-2013, 10:14 PM | #3 |
01-05-2013, 10:20 PM | #4 |
やりすぎだ~
That's the magnetic clitoris enhancer.
You can tell by the opening. |
01-05-2013, 10:23 PM | #5 |
01-06-2013, 02:54 AM | #6 |
Drives: 2013 Yaris Join Date: Oct 2011
They forgot to add things like
adds 5-10 HP, and other misc stuff like turning your car into a hybrid and giving it the ability to make you grilled ham and cheese sandwiches while you drive, while simultaneously doing your dishes and your neighbor kids homework! didnt this start out as some sort of farmer's trick for something a long time ago? |
01-06-2013, 08:28 PM | #7 |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
Add that to the electric supercharger:
Cheapest DD I could find!! |
01-07-2013, 01:27 AM | #8 |
those remind me of my friend...he wanted to attach an electric blower to his intake to act like a supercharger.....I love him to death, even when he's being silly, lol.
01-07-2013, 03:47 AM | #9 | |
*May or may not be true.
"Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
01-07-2013, 05:29 PM | #10 |
Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Which one of you clowns voted 'yes'?!?
01-08-2013, 03:13 AM | #11 |
This is an open poll. If you click on the number 1 next to yes it will tell you who voted yes.
01-12-2013, 06:15 PM | #12 |
01-12-2013, 10:25 PM | #13 | |
MADDOG, get your facts straight! The hover car upgrade only works on a DMC-12... So, unless your car looks like this: you will not be able to use the Powermag Magnetic Fuel Saver to get your car into hover mode... (It has something to do with the interaction with the stainless steel body work of the DMC-12 and the magnetic fields generated when the Powermag is optimizing fuel flow.)
01-15-2013, 02:45 PM | #14 |
Drives: 2012 Yaris L, 2020 Yaris LE HB Join Date: Jan 2013
I do believe this is yet another scam to lighten the wallets of the unsuspecting. For me, I shall pass on this particular fuel economy enhancement.
01-19-2013, 07:11 PM | #15 |
Drives: red Liftback Join Date: Aug 2007
Air Swirler...
The gas line magnet...reminds of a device that a friend of mine put in his carburetor. It looked like an aluminum turbine blade. It was supposed to 'swirl' the air as it went through the carburetor throat to better mix the gas with air.
He found no change in mileage until one of the blades broke off and went into the engine. He didn't use any more gasoline until they took the engine apart to repair it. |
01-19-2013, 08:39 PM | #16 | |
play every day
They used to call DeLoreans "snowmobiles" because it took coke to get them running. |
01-20-2013, 12:28 AM | #17 |
Drives: 07 Yaris sedan Join Date: Jun 2007
Hahaa.. This junk has been around as long as the automobile. Even the manufacturers aren't above such rubbish, look at some of the ads from the 40s and 50s to see what I mean. Mr. Nelson is right...
01-20-2013, 02:54 AM | #18 | |
Drives: yaris 08 sedan Join Date: Oct 2008
Most car companies have billion dollar research and development departments dedicated to getting the best performance out of a car,odd gimmicks like the one here have usually been tried and tested and found to be useless,if they did anything at all you can bet they'd be standard equipment on most cars.
Have Yaris will travel.. |
Tags |
fuel saver, magnetic |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 325 | 05-12-2024 01:43 AM |
The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
