Old 04-29-2012, 02:41 PM   #1
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
jpmck03's Painted Emblem Experiment
So, I've always been a bit interested in blacked out emblems, but never liked that the front emblem would be a black "sombrero" or "Netz" on a black background. My ideal solution: paint the emblem with two colors, color-matching the back and blacking out the front emblem... like so...
Doing some research on the best way to clean up the chrome, I found this DIY over on a Mazda 3 forum: Topic: DIY Painted Emblems (the right way) (Read 100261 times)
Long story short, you soak the emblem in bleach, which chemically breaks down the electroplated copper and aluminum (it's not real chrome on that plastic... who knew? :p ) After a few days, you end up with an emblem free of chrome and ready to be painted. A bit of a time-consuming process, but a little more of a "sure thing" when painting the emblem.
So, I've taken my spare Netz emblem apart...
...and have started the fun chemical bath treatments...
..so far so good!
- to be continued... -
Old 04-29-2012, 03:25 PM   #2
12 yaris
Drives: '12 Yaris LE Lagoon Blue Mica
Good luck,should come out nice.
12 yaris is offline   Reply With Quote
Old 04-29-2012, 04:01 PM   #3
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Thanks, man... I'm hoping that it turns out well!
So far I'm on my 3rd or 4th bleach bath and more and more of the "chrome" is coming off. Apparently sometimes it can take several weeks, but at the rate that it's going now... probably should take 3-4 days.
I'll update the thread then...
Old 04-29-2012, 10:55 PM   #4
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Went over to my parents for dinner and when I came back I found that my little bleach bath turned into a bubbling caldron of black liquid... The nail and bread tie was to keep it from floating to the top, all the bubbles kinda nullified my little improvised weight system.
"Chrome" is coming off rather quickly, which is good...
Back into the bleach it goes... This time with a bigger improvised weight.
Old 05-01-2012, 11:30 PM   #5
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Picked up some paint and bleach and did a little test painting to see how satin black would look... I like it!
After some more baths in the bleach...
And finally clean...
Old 05-06-2012, 12:05 AM   #6
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
I've been thinkin bout doin the same....but never know how to go about it.....and btw could'nt you use some paint remover?
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 05-06-2012, 01:17 AM   #7
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Like paint stripper? I was under the impression that it wasn't very plastic friendly... and I don't know if it would be effective at removing chrome...?
Old 05-06-2012, 01:24 AM   #8
Qmobile
Qmobile's Avatar
I think the chrome is just paint but idk...How'd you get the emblem and back appart?
Old 05-06-2012, 09:08 AM   #9
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
The "chrome" one the emblems is electroplated aluminum over electroplated copper:
Originally Posted by jpmck03 View Post
... Long story short, you soak the emblem in bleach, which chemically breaks down the electroplated copper and aluminum (it's not real chrome on that plastic... who knew? :p )
To take the two halves apart I used an Xacto knife around the outside, then pulled up the outside enough to clear the two alignment pins. After that I just twisted it to break the emblem free from the tape holding it to the base. The I just cleaned up the tape that was on it.
Old 05-06-2012, 11:07 AM   #10
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Thanks for sharing that clever technique... now I want to do mine, too.
Old 05-06-2012, 11:18 AM   #11
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
If you work quickly with most paint strippers they wont harm the plastic, the stripper seems to work pretty fast..."quickly" is like 30 seconds of aggitating the stripper by hand(with a glove) and then quickly rinsing in water. Repeat as necessary.
I test a small portion of the plastic first before i go all in, i think its only been a "no-go" twice to date.
I've used paint stripper(a tiny tiny dab on a rag) to remove overspray from painted rims, plastic, glass, etc. The rag is always follwed by a dripping wet rag(water), which i use to wipe down a perimeter larger than yhe spot i was working on to make sure no stripper is left behind.
**BE VERY CAREFUL IF YOU GO THIS ROUTE, IT'S RISKY**
-Type 07 FFL-
My odometer 03/11
Old 05-06-2012, 11:33 AM   #12
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
That's why I went with the slow and boring (yet interesting) give 'em a bleach bath for a week!
Old 05-13-2012, 07:31 PM   #13
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Got the back done... primed, base coat and clear coat...
Not too shabby! Still debating on what order to do the "two-toned" portion on the front part of the badge (i.e primer, color matched inner portion, black outer, clear coat, etc.) and what the best way to mask them off...
to be continued until then!
Old 05-13-2012, 11:15 PM   #14
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Are you going to have to remove the paint on the mating surfaces?
Old 05-14-2012, 12:10 AM   #15
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
You mean where I'll be sticking the two halves of the emblem back together? (In red)
I wasn't planning on it, as when you reattach say a regular emblem (like putting on a "Vitz" emblem) you don't remove the paint from the body.
Am I understanding your question correctly?
Old 05-14-2012, 06:51 AM   #16
CrankyOldMan
Yes. I'm not sure what you're using to bond them back together, and any kind of solvent-based adhesive would need plastic-on-plastic contact. Double-sided tape?
Old 05-14-2012, 07:54 AM   #17
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
They were stuck together with double-sided tape originally, so I'm just going to put them back together the same way!
Old 05-18-2012, 07:16 PM   #18
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
It's getting there... masking job didn't turn out as well as I'd like it... probably going to use the little touch-up paint pen from the dealer to get into the corners.
blacked out, color match, emblem, netz, painting
Toyota Skull Emblem GB Feeler... fnkngrv Cosmetic Modifications (Exterior/Interior) 261 10-20-2010 05:29 PM
Painted my Netz Badge custom Lftback Cosmetic Modifications (Exterior/Interior) 22 05-28-2009 10:49 PM
blank front emblem? YAR1S Willing to Buy by private party 3 04-13-2009 06:43 AM
Rear VITZ Emblem & Hatch Opener Painted Polar White. [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 39 05-04-2007 05:20 PM
