02-15-2009, 08:38 AM | #1 |
Drives: 2003 Mach 1 Join Date: Oct 2008
Anyone running Royal Purple?
I've always had it in my Mustang and am considering using it in the Yaris too...right now the car only has 1000 miles on it with the factory oil. Any suggestions on when to change to synthetic?
02-15-2009, 09:30 AM | #2 |
Drives: Toyota Yaris Join Date: Oct 2008
did my switch on my first service 5000 km's with rp
02-15-2009, 10:33 AM | #3 |
02-15-2009, 11:55 AM | #4 | |
Compulsive Washer
I'd suggest doing it yourself, and leaving the care about an hour to drain the old oil, so you get as much of it out before putting in the new one. |
02-15-2009, 12:05 PM | #5 | |
02-15-2009, 12:09 PM | #6 |
Compulsive Washer
That's about it. Just be really careful not to overfill, and to store the oil somewhere to keep it from hurting the planet.
I'm almost sure there's an oil chance DIY guide somewhere in here, not sure if it was before the hack tho.. |
02-15-2009, 01:16 PM | #7 |
Drives: 2008 Yaris Sedan Join Date: Oct 2008
Royal Purple is great, but AMSoil is better. Plus AMSoil comes in 0w20, whereas Royal Purple only comes in 5w20. That said though, my dad runs Royal Purple 0w40 in his 996TT-S and it seems to perform better than when he was running Mobil1 0w-40. (1% more power, 1mpg better FE, 2% less oil consumption -- all of which can be placebo effect, but who knows?)
02-15-2009, 02:06 PM | #8 |
Drives: 2008 Yaris Hatchback Join Date: Nov 2008
The Yaris is the easiest of all cars to change oil. I have the 2" TRD lowering springs on mine and I don't even jack my car up to change the oil. I am running the Royal Purple in my car now and it seems to run a little smoother than the Mobil 1. I use the K&N oil filter as well.
2008 Meteorite Metallic Hatchback, TRD lowering springs, TRD rear sway bar, TRD exhaust, 17" LiquidMetal wheels w/ Yokohama "S" drive wheels, 10" Fusion subwoofer w/ 400 watt amp, infiniti speakers, AFE stage 2 CAI, 35% window tint, wind deflectors, euro taillights, NST SSK1 & SSK2, and NST lightweight pulleys!. |
02-15-2009, 02:27 PM | #9 | |
02-15-2009, 02:29 PM | #10 |
The K&N oil filter. I have the AFE CAI.
02-15-2009, 07:35 PM | #11 |
Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
HAd RP and dumped it after a week. Got MOTUL in there now but its the economy grade and not for rompin on the revs. RP gave the most power at the top of the rev band but somehow seemed sluggish down low around town. I assume you mean the RP std street oil, 5W-30, not the fancy race formula? Rp street, Its not full synth so changeover shouldnt be a prob.
02-15-2009, 07:37 PM | #12 |
Get one of thouse plastic cup-type filter wrench heads to help get the filter off. Works miracles. Only 3.5 Qts on th refill - 1/2 qt stays in the engine no matter how hard you try to drain it.
02-16-2009, 07:48 AM | #13 |
Drives: 2007 Yaris Sedan Join Date: Nov 2008
02-16-2009, 08:04 AM | #14 |
Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Did Toyota issue an updated TSB? Their last one didn't recommend 0w-20 for the Yaris.
02-16-2009, 12:30 PM | #15 |
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
That is my question! Does anyone online use the 0W20 in their Yaris? I would be interested to know if there was a jump in mileage for going to 0W20?
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! |
02-16-2009, 12:45 PM | #16 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
For the millionth time! See attached official Toyota TSB, and you will see that the Yaris 1.5L engine can use 20 weight. And yes, I've been using 0W-20 in my Yaris for the past 54,000 miles. Increase in MPG is just around 1% however. I use the light stuff so that it gets circulated quick during cold morning starts. Quick circulation means less wear and tear during the first start up. And it is during the first start up that 90% of engine wear happens. My engine does not consume any oil after 5,000 miles. The engine runs smooth and no strange sounds coming out of it either. |
02-16-2009, 01:14 PM | #17 | |||
It states 5w-20 NOT 20 OR 0w-20 Quote:
02-15-2009, 07:51 PM | #18 |
SIPNDEW
i use RP 5w30. love it! i also use the 75w90 trans fluid as well.
Similar Threads | ||||
Royal Purple Transmission Fluid | caveatipse | DIY / Maintenance / Service | 14 | 01-09-2010 03:02 PM |
Aside the name,y is Royal Purple purple? | Yawesh | General Yaris / Vitz Discussion | 6 | 01-10-2009 06:50 AM |
AMSOIL vs Royal Purple | IllusionX | DIY / Maintenance / Service | 44 | 12-02-2008 12:35 PM |
Royal Purple FTW | Nibs | DIY / Maintenance / Service | 11 | 09-28-2007 01:06 PM |
Anyone familar with Royal Purple synthetic oil? | Yaris_Fan | DIY / Maintenance / Service | 34 | 06-23-2007 12:29 AM |
